was in hervey bay on the weekend and saw a clean 32 gtst with large white? rims pulling in to the BP near hungry jacks, also saw a silver 34 with no wing cruising around on saturday night near the BCF building
Spotted & gave a toot as I pulled up next to a 4dr 34 crawling through the mind numbing traffic of Virginia/sandgate rd today in one of my many attempts of finding quicker ways home.... An hr long journey became 2 hrs....
Spotted tonight.
White over silver R31 S2 Silho @ Brassall.
Black R32 4 door on the side of the road at Goodna with the bonnet up.
Red R33 with SAU QLD sticker on passenger side rear window, cruised with it from Goodna to Mt Cootha round a bout.
Black R35 GTR on Newmarket Road.
I was in my silver R34 coupe.
Passenger in a Richer's tray truck thought he recognised me, got a huge wave on Thursday near the duck ponds.
Lots of grey 32's around but no-one knows me.
Keep seeing a red 34/4-door everywhere lately.
Gympie = Nissan town.
ahaha, i know what you mean. i'm starting to feel like a minority in my commodore.....
ans spotted a 33 heading south on the highway south of gympie (at the roadworks). it had a headlight out and a tail light out as well
have seen a purple r32 (i think GTR) with the plates U LOSE going past work a few times during the week. could normally hear it coming as the driver seemed to be doing a good job of enforcing the media's view of import drivers (although not as much as some others that come past work)......
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
