  • 1 month later...
Spotted 872KLL a nice gtst 32 in surfers centro car park today... i giggled, then i took a picture,
if you are on here, it is good to see a fellow skyline driver who cares about their car.
dont think you could have hugged the pole anymore...
This is so cool to see, I own the car now after 8 years from this photo. She's still going strong. IMG_3211.JPG
probably has less kms showing on the dash since then as well
  • Like 1
  • 3 weeks later...
  • 8 months later...
  • 2 months later...
  • 3 weeks later...
  • 2 months later...
  • 1 month later...
  • 3 years later...
  • 1 year later...
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
