I've worked in the compliance industry for a number of years and came across a motor which had a very usual marking on the engine block when I was attempting to get the engine number. It was in a 1994 R32 GTR Vspec with the an engine number that was something along the lines of the following
R B 2 6
R
7 * * * * * X
(The R should sit directly above the X marking)
I believe the X denotes that the block was sold seperately from nissan. That when a engine block is bought from nissan it will have this marked on it and the block requires it to be restamped. What I don't get is what the R marking above the X stands for. The stampings all look factory, but I could be mistaken. Does anyone know what this R marking could stand for? Does it mean that it is an N1 motor?
I also pulled the front cam cover off and all the bolts where brand new, as if it had come like that from factory. I'm quite baffled to know what it could be..
Edited by Baz
https://www.sau.com.au/forums/topic/192670-rb26-block-with-r-engine-number/
Are you sure it doen't have RRR on the side ? If it did thats a Nismo Gt block , the engine number then would be NS Axxx, only 3 digit number from 1 to 200 , only 200 Nismo GT blocks made.
The number on the block that has .........X and then a R above is definatly a R34 Nur engine, these engine's are build by Nissan Motorsport and have the following specs in stead of the STD Rb26:
- R34 NUR cams little different then STD R34
- N1 block (24U)
- N1 piston rings
- piston + conrods weight balanced
- crankshaft weight balanced
- Nismo F112 bearings main + conrod
- N1 oil pump
- N1 waterpump
As you state all the bolts, nuts, the complete bare engine is new from Nissan Motorsport.
Here are some pics of a few I have/had:
Yup.. the engine number on the side of the block was exactly as the same as the one on the picture as above. The only thing I though is that it did not have variable valve timing such as found in the R34 GTR motors. Does that mean that it is not a R34 NUR motor then?
VCT is what I meant to say. Where exactly would the 24U be stamped on the block? Because I'm pretty sure there was a 05U cast into the underside of the block.
No they don't have VCT either. Where do people hear these crazy things?
On the passengers side in line with the collant outlet , close to number 3 cylinder, not easy to see under the turbos, you have to look up from under the car.
  • 1 year later...
G'day,
Can anyone please send me pics of the RRR block engine stamp. I believe the numbers and letters are actually raised not stamped as such, any help would be appreciated,
Thanks
KG
If you read my post above you will note that the Nismo GT block had RRR in caps ( just like the normal 5uand 24U blocks) on the turbo side close to number 3 cyl inline with the coolant pipe.
The engine number is in the normal place on the inlet side near the dipstick, RRR blocks have RB26 NS Axxx, just a 3 digit number from 001 to 200 , only 200 blocks made.
  • 7 months later...
Wondering if R means refurbished or remanufactured?
yeaqh ive seen this on a few cars that had reco's in japland. I stamp all mine to and engrave certain things on the wings to remind me whats inside :)
  • 3 years later...
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
