I have it confirmed, there is no Australian Nissan with Standard (Factory) GPS. So no Nissan maps, the unit's use an add on box/wiring GPS that is either dealer fitted (option) or is installed at the dock, in the Nissan holding yard when 'imported' for an Aussie owner. Nothing is installed at the Factory...
As stated the unit uses Siemans software via a memory card of which there is a chance I can get to see one soon. Presumeably, it can be replicated. Incidentially it is a $330 spare part as an upgrade and it is installed in the car behind the glovebox of a Murano and Patrol. It stays with the car in order to work and is not downloaded via a disc.
Does this help?
Unfortunatley I don't think this will help. What we need are the digital maps that can then be coded correctley to work off DVD in the right orientation in Aust.
Cheers
Andy
https://www.sau.com.au/forums/topic/194126-software/page/8/#findComment-4077556
Cheers
Andy
Yes I think you are right, but this card will have the maps on them, just not sure what format that they are in.
To compare with my Mobile Phone GPS Software (Sorry if that is a bit crude) that I downloaded off the net, I think that the program that runs the maps will need to be able to read it. So if it is a Nissan Aust part, then the format may be close, even if it is just a Seimans unit.
Either way there is no other unit installed in an Australian Nissan and I don't think we will find another option.
As a guess, perhaps Nissan has a commercial agreement with Siemans and globally all maps are in this fomat. Without finding the files and taking a look at them in comparision with the Japan maps we will never now.
Just a long shot... but one that I will try to investigate.
https://www.sau.com.au/forums/topic/194126-software/page/8/#findComment-4077614
actually no. nissan has agreements with suppliers of maps world wide - ZENRIN - US market. Xenavi - Japan market, Siemens/VDO - Oz market.
been down this path already and I donated a siemens disc quite a while ago.
have a quick dig on this. it has been covered already.
https://www.sau.com.au/forums/topic/194126-software/page/8/#findComment-4100022
The guys from Xanavi in Russia are working on a conversion for the computer from Jap to English for all the screens except the GPS functions. They have said this would be ready around June.
It is as simple as putting in a disc in your DVD rom drive, press a few buttons on screen and then the computer is upgraded to English.
Price is not confirmed and timing still to be locked in but pushing for it as soon as possible.
Cheers
Andy
G'day,
Any updates on the language conversions from Xanavi yet
Cheers
Jason
https://www.sau.com.au/forums/topic/194126-software/page/8/#findComment-4100281
wow just went through all 8 pages. i have a 2003 model i think but it has a dvd rom. can mine be converted :P
but from the imformation i've read no. but just wondering r they making 1 for the 2003 models? and r they making the english buttons?
Edited by skylinesrus
https://www.sau.com.au/forums/topic/194126-software/page/8/#findComment-4103423
English button kits come up in ebay from time to time for V35
https://www.sau.com.au/forums/topic/194126-software/page/8/#findComment-4103524
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
