once changed thats it.
You can actually change it back. We have a run back disk which we can reload back to normal if you don't like the conversion. Or you could just get a Japanese firmware disk and put that in.
Yeah that's what I meant - I got the original firmware disk that came with navi disk when I bought the car. Definitely want to check it out when it's ready.
Really like the KLM/L reading very easy to follow 8klm a litre x 80litre=640 (always fill around 560ks on this average). Why the standard on all new cars went to litres/100klm is beyond me.
Thanks Brad
Hope this answers a few questions.
Quoted from Fedor "Yes, series 2 will be somewhat the same. There are no significant changes/additions in functionality. It will have L/100km.
No, it is not the last conversion. I'm working on later (HDD) models in parallel."
industry standard.
Just like how they got it wrong with the direction of the tiptronic- but people will swear they like it till the cows come home. Doesn't mean they got it right.
I swapped the direction of that too... :yes:
I fully get the gearbox tip tropic thing. Cause pushing forward should always be up I reckon (must be a manual driver thing). But on fuel just looking at it practically how do you work out litres you got- you have to covert range left /. 100 klms/ then. / litres. Its always a 2 step process before you start. So I guess like the gearbox thing "Industry standard "is not always practical
I disagree with the auto shifting. Think about it guys. Before the manualised auto came into play, you had the sequence PRND21. So invariably, you had to push up to shift to a higher gear.
Grab a B&M auto shifter and it is the same thing, with the sequence also ascending gears upwards.
Maybe some of us are just too old school to understand you young whipper snappers. ;)
Edited by The Max
lol, well this thread is careening off topic at a rapid rate.
a) shutup Alex, you're wrong :P How is L/100 industry standard? Maybe here in Aus it is, but it is a ridiculous and illogical form of measurement. Km/L or Miles/gallon (which had been the industry standard around the globe - so when changing to metric, why change it completely?) make much more sense
b) Agree with Elie and Alex (okay, only half wrong :)), pulling down on the shifter to change up through the gears works with g forces whilst accelerating and vice versa when braking. Natural feel IMO
If your names Tony you must like it huh? B&M shifter...is that all you got? :whistling:
How about a hollinger, or a Porsche GT3 cup car, V8 supercar? Suppose they got it wrong- better tell them.
Cam - open the paper to the car reviews. What do you see economy measured in? Ever seen MPG or Km/L lately? Thats what I call industry standard, and so other car companies that see in Aust. Toyota, ford, holden all in Lts/100kms. The car has a range display, so knowing how many litres left is largely useless.
Anyway, the Russians agree with me. Don't like it, go design your own software :P
Yes, that is all I've got because logically, you don't compare race vehicles to street-legal vehicles. You can at least use a B&M shifter on a vehicle that can be kept street-legal after the modification.
Don't get me wrong, I don't disagree with which sequential shift pattern is better. The idea of pulling the shifter towards you to shift up makes sense to me but given the old PRND21 sequence we've all grown up with, it makes sense to keep it that way on a street vehicle. That's why I didn't bring Hollinger into the argument, despite their transmissions being widely accepted in the racing community, particularly in V8S as their control transmission for a while.
I couldn't disagree with this more. Traditionally car manufacturers have used motorsport as a testing ground for their technology before integrating it into their road cars. This may not be as true today as it was 20+ years ago with so many manufacturers having little involvement in motorsport but who on this forum would ever buy a car from one of those manufacturers anyway?
  • 3 weeks later...
So maybe there is hope out there for V36 owners - spotted this ad on TradeMe (NZ auction site) the other day - a 2005 Nissan Fuga being advertised as having the navigation system converted to NZ:
http://www.trademe.co.nz/motors/used-cars/nissan/fuga/auction-496051466.htm
The advertiser (Croydon Wholesalers) is a well known importer of Nissans, and Skylines in particular, so doesn't surprise me they figured it out.
The Fuga is kinda related to the V36 - wonder how close a cousin the AV system is?!
Is this one of the registered V35 AV converter guys - charging NZD$499 for the conversion in NZ?
http://www.trademe.co.nz/motors/car-parts-accessories/rear-view-cameras/auction-533190114.htm
Makes me a little bit suspicious since there is a q posted there about a series 2 M35 which should have been a dead giveaway that it wasn't supported, but their initial answer to the q was that it was (they later reported it correctly as not supported).
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
