looking to get my guards rolled to fit 18 x 275's on the ass of my 33 gtst, and 255's on the nose
any ideas on where to go that will do a good job (heated etc) and probably not fcuk my paint?
i searched some (not much admittedly) and only really found threads from a few years back which probably don't apply anymore and have a heap of closed workshops (like when i went down to ICE performance, who incidentally still have their website up) :rolleyes:
Edited by joeyjoejoejuniorshabadoo
https://www.sau.com.au/forums/topic/194650-guard-rolling-in-vic-se-burbs/
give police rd panels a call, speak to harry, tell him you are from the skyline forums.
he doesnt like rolling the guards as the paint usually cracks so he suggested he shave some of the inside of the lip..
worked a treat, dont rub, cant tell its been cut and looks 100 times better than a rolled guard.
PM 180athid on here, flared my 33 rears out about 30mm.
Top job, top prices!!
[EDIT]Im also running 275's on the rear, id say if u got a high enough offset ull only have to lip the guards.
U dont really wanna roll the guards cos u bust up the crease on the 33, unless u got GTR rear guards to go over and bring back that 33 shape.
Edited by ABuSD
Mick at Micolour.
If you dont want to stuff your paint then you can trust him. Mind you, if your gaurds have any bog in them at all they will crack straight away.
Mine were done before painting i will add. but they look shit hot.
Dont go to the tire factory in Dandeenong. I took my last car there and they rolled the shit outa my gaurds and F*%#ed them. I ended up selling the car cause it was gonna cost me to much to repair. C*(k heads. Some young apprentice dude did em and they didn't even ask me. I mean f*&ck I cracked the shit at them and didn't pay. To top it off the new wheels still rubbed. I woulda been better off just raiing the car up and inch or two.
Oh well I got a new beast now!
Been burnt by them too. See the thread on wheel spacers. Avoid them is my advice.
Avoid TTF in Scumshine also!!
Although he doesnt know it yet, Athids probably gonna be flaring my fronts (if poss), so ill throw up some pics when/if done.
Trent, answer my messages, ive got business to send your way ;)
Edited by ABuSD
Mick at Micolour.
is it really possible to flare stock front guards? i got told that it was a no go...? don't need much, only slightly.
Athid - you did the rears on my gts4 nicely...wanna do the fronts on my gtst?
Athid is KING
Seen his work. R-E-S-P-E-C-T
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
