  • Replies 94
Mine was the Lotus Esprit V8 Turbo which came from playing the original 1987 PC game Test Drive (check out those graphics!). This was despite the fact that the Countach and the Testarossa were faster cars in that game - I just loved the look of it.
Gotta be the big bad "last of the V8 interceptors hey" black falcon coupe in Mad Max...... (the rest of this post is unimportant).......
+1
"kick in in the guts, Barry!!"
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
