Hello,
Well I asked my dealer that exact question as I wanted a towbar to carry the kids bikes, didnt really need to tow anything. I wanted it on my AXIS.
He told me it is not as easy as the Series 1 & 2 Stageas, As there is a lot of components where the bar would normally get welded, apparently there is a pump for the drive line or some sort of fluid transfer case. "Please correct me someone if I am wrong"
He said it can be done but it is a lot of work. Surely they do it in Japan
If you find out more I would really like to know, I need to carry the bikes.
I was going to ring Carasel out liverpool way, they did a great job in my 4WD, maybe they can do something.
Jules
Edited by Paramour
Hello,
Jules
I am trying to remain positive! Although now planning to buy another car - probably a Land Rover!
There would appear to be some kind of pump right where a normal towbar would attach. I think it would be tricky and expensive to fit a towbar, but - when and if I finally get to drive the car - I will take it up to the local towbar place, who make them from scratch rather than just look through a catalogue - and get their opinion. I think the Subaru Liberty / Outback wagons tow around 1500-1800 kg so I assumed the Stagea might be the same. Although without closer inspection it's impossible to tell. I don't recall seeing one on any of Nissan Japan's options lists.
I've been quoted $420 NZ for a towbar by a guy who has fitted to m35 before. Is a lot of work yes. 2 tonnes is the limit but sensibly the weight of the car braked and 750 kg unbraked.
If you do decide to get one before us, could you be so kind as to take a pic so we can see where they have welded it etc. I will return the favour if I get it done first.
Jules
  • 1 year later...
Was just about to start a new thread but saw there was a topic about towbar's for M35 so though I would add to it instead.
I was told today that some one in Sydney now has a design to fit a tow bar to the M35. I do not know the specifics of the tow bar or the cost yet but I believe that will be available soon.
My reliable source was Ben, at North Shore Prestige.
Looking better all the time.
Cheers
Andy
  • 2 years later...
Well guys I might be throwing a spanner in the works.
I currently have a 2001 Jackaroo 3.0L Diesel for my tow car rated at 2500kg braked capacity with an Hayman Reece Receiver Hitch and have been looking at replacing it with an M35 Stagea.
I just contacted Fast Fit Towbars in Sydney (02) 9569 4217 and put the question to them. They tell me they have fitted towbars to the M35, but with a max capacity of 1200kg braked.
It would be excellent if I could get up to about 2000kg, so if anybody finds information above 1200kg, I would be very interested.
Cheers, D
I have the Fast Fit one installed and its very nice but you're right its a 1200kg max load. I must say however though that the installation quality is impressive. Its all hidden behind the rear bumper so it is very clean and they installed it within about 3 hours on a Saturday morning for me.
I doubt you'll get more than 1200kg on the back of an M35, mostly because there is no rigid chassis back there to bolt it to. If you hang more than 1200kg off the back of a Stag you will probably bend the body.
I'm also looking at a M35, and it would top it off if I could tow my racecar on it. I did read on here that it could be done, but needed reinforcment? any details or price on that?
My mate tows his racecar with a vt commodore equipped with rear airbags, and that tows fine. I don't see why the M35 wouldn't be able too, it's heavier, more hp & torque, awd with the equivelent of a centre diff lock, and you can easily get with with a LSD.
There are several good shops over here on the shore, two I have spoken to about my rwd 300 recently and both claim to have fitted units before.
All I need to tow is a large trailer with either two road bikes or three dirt bikes + gear. Both confirmed that this would be no problem so I'll be getting one fitted at some point soon.
"A1 Exhaust & Towbar" or "North Shore Towbars" here on the shore in NZ would be the dudes to call for specs and limits.
price?
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
