Hello,
Well I asked my dealer that exact question as I wanted a towbar to carry the kids bikes, didnt really need to tow anything. I wanted it on my AXIS.
He told me it is not as easy as the Series 1 & 2 Stageas, As there is a lot of components where the bar would normally get welded, apparently there is a pump for the drive line or some sort of fluid transfer case. "Please correct me someone if I am wrong"
He said it can be done but it is a lot of work. Surely they do it in Japan
If you find out more I would really like to know, I need to carry the bikes.
I was going to ring Carasel out liverpool way, they did a great job in my 4WD, maybe they can do something.
Jules
Edited by Paramour
Hello,
Jules
I am trying to remain positive! Although now planning to buy another car - probably a Land Rover!
There would appear to be some kind of pump right where a normal towbar would attach. I think it would be tricky and expensive to fit a towbar, but - when and if I finally get to drive the car - I will take it up to the local towbar place, who make them from scratch rather than just look through a catalogue - and get their opinion. I think the Subaru Liberty / Outback wagons tow around 1500-1800 kg so I assumed the Stagea might be the same. Although without closer inspection it's impossible to tell. I don't recall seeing one on any of Nissan Japan's options lists.
I've been quoted $420 NZ for a towbar by a guy who has fitted to m35 before. Is a lot of work yes. 2 tonnes is the limit but sensibly the weight of the car braked and 750 kg unbraked.
If you do decide to get one before us, could you be so kind as to take a pic so we can see where they have welded it etc. I will return the favour if I get it done first.
Jules
  • 1 year later...
Was just about to start a new thread but saw there was a topic about towbar's for M35 so though I would add to it instead.
I was told today that some one in Sydney now has a design to fit a tow bar to the M35. I do not know the specifics of the tow bar or the cost yet but I believe that will be available soon.
My reliable source was Ben, at North Shore Prestige.
Looking better all the time.
Cheers
Andy
  • 2 years later...
Well guys I might be throwing a spanner in the works.
I currently have a 2001 Jackaroo 3.0L Diesel for my tow car rated at 2500kg braked capacity with an Hayman Reece Receiver Hitch and have been looking at replacing it with an M35 Stagea.
I just contacted Fast Fit Towbars in Sydney (02) 9569 4217 and put the question to them. They tell me they have fitted towbars to the M35, but with a max capacity of 1200kg braked.
It would be excellent if I could get up to about 2000kg, so if anybody finds information above 1200kg, I would be very interested.
Cheers, D
I have the Fast Fit one installed and its very nice but you're right its a 1200kg max load. I must say however though that the installation quality is impressive. Its all hidden behind the rear bumper so it is very clean and they installed it within about 3 hours on a Saturday morning for me.
I doubt you'll get more than 1200kg on the back of an M35, mostly because there is no rigid chassis back there to bolt it to. If you hang more than 1200kg off the back of a Stag you will probably bend the body.
I'm also looking at a M35, and it would top it off if I could tow my racecar on it. I did read on here that it could be done, but needed reinforcment? any details or price on that?
My mate tows his racecar with a vt commodore equipped with rear airbags, and that tows fine. I don't see why the M35 wouldn't be able too, it's heavier, more hp & torque, awd with the equivelent of a centre diff lock, and you can easily get with with a LSD.
There are several good shops over here on the shore, two I have spoken to about my rwd 300 recently and both claim to have fitted units before.
All I need to tow is a large trailer with either two road bikes or three dirt bikes + gear. Both confirmed that this would be no problem so I'll be getting one fitted at some point soon.
"A1 Exhaust & Towbar" or "North Shore Towbars" here on the shore in NZ would be the dudes to call for specs and limits.
price?
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
