  • Replies 3.9k
Posted Images
Will Button have another hack year? LOL, the guy seemed to be over it last year, and even though his year was much worse then Webbers, Webber is always soundign hungry for a result and disappointed when the pace or relaibility wasnt there. Button didnt seem to care.
But most of all will be the new pairings. Jr v Alonso and Heiki vs Louise
Who's Jr?
Don't get it why Alonso wants to go back to Renault now. >_<
What was the news about Alonso? Anybody refresh my memory? :dry:
Jr is Nelson Piquet Jr, possibly one of the most over rated drivers on the grid this year (imho) Alonso wanted him as a team mate so that he wouldn't have any competition (a la Lewis) and got Renault to get rid of Hiekki to accommodate him.
Alonso is back a Renault because he wants Flavio to stroke his Ego and blow smoke up his arse about how good he is.
If the Honda management goes totally hands off and lets Ross Brawn do his job, then I can see Honda making great steps forward this year, as long as the car isn't totally shithouse like last years, and they can get a good test/development driver into the team.
not forgetting that he won 2 GP drivers championships there
but obviously that's history anyway
God... the front of the new F2008 is horrible, its like it gets worse and worse every year. You'd think with all the money they have there would be a more elegant solution to attaching a wing to the nose. The intakes and bargeboards do look nice tho, but the new MP4-23 gets released today... cant wait
I think the single lap pace of drivers will not change much, even without TC. Sure there may be a few errors here and there when the pressure is on. But they are all talented guys and i dont see it being a great leveller between the quicker and weaker teams. Especially after an off season of testing
Where i see it making a big difference is over the race distance. I think some will pick it up quicker then others and be able to get their tyres to wear better. So it may mean that pit strategies are a little less flexible now because drivers will be torching tyres when they are trying to bridge a gap
Bring on testing and Honda once again being pace setters :D Only to... :yes:
While what you have said will be true for the guys who have real talent, I do think that it will be a leveller for the rest of the field.....over the years that the cars have had TC the amount of times it cuts in during a corner when they show incar footage staggered me. Now that the driver will have to step up and actually control an F1 car around a corner whilst maintaining tyres etc I think we will see the talent seperated from the rest.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
