  • Replies 3.9k
Posted Images
It wasn't just the Ferrari F1's that had engine troubles at the GP
Speaking to a mate in McLaren, they are very happy with the results and aren't worried about the engines/gearboxes for Malaysia. I think its going to be a silver and red year from what he was saying.
Haven't heard from Red Bull yet (and haven't chased) cos i know what they will be saying
lol
quote of the week
"Engine problems are unusual for a team like ours." (Stefano Domenicali)
he musn't have been watching team jihad throught out th 70's 80's and 90's
kimi's exhaust sounded like it had cracked, i have a video where you can clearly hear it, so i dont know if you can read too much into that one
Edited by ctjet
yes I wonder how much of these problems can be attributed to everyone having to run a maclaren ECU? it certainly didn't seem to get along too well with the ferrari's...
Well all engine failures are electrical. Especially when a piston spits out the side of the block & nails the alternator.
Anyway I guess it is so much better for the PR people if they can blame another team for their own inability to write proper code.
FOR SALE: For sale: Scuderia Toro Rosso
Red Bull founder Dietrich Mateschitz has said that his second Formula 1 team, Scuderia Toro Rosso, has been put up for sale. Mateschitz wants to focus on his team Red Bull Raacing and as the Concorde Agreement won't allow customer cars from 2010 Toro Rosso will have to build the entire car themselves.
Speaking with Motorsport Aktuell Mateschitz revealed: "We have Toro Rosso on the market and are looking for the right person to purchase it. At the start of the 2010 Formula 1 season there will be a rule change that says we can not build both Red Bull Racing's car as well as the car for Scuderia Toro Rosso. That is why I believe we should continue with one team only."
Mateschitz furthermore revealed that it is not planning to sell the team in 2008 already, but before the start of the 2010 Formula One season.
There are already a handful of candidates being speculated as possible buyers. Among them Nicolas Todt, son of Jean Todt and manager of Felipe Massa. But also A1GP chairman Tony Teixeira is being mentioned as a possible buyer.
SAU could pool it's money. Only a couple of buck s each, providing we can sign up every man, woman and child in this hemisphere.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
