  • Replies 3.9k
Posted Images
yeah i don't like "rusty" either.
odds are against massa, not only does he have to come #1 but louise has to come #6 or #7 (? haven't checked points)
oh the anticipation is killing me!!!!!! GO MASSA!!!!!
hey when does the race actually start? coverage is 3.30-6am but I dont want to get up at 4 and find the race started 15 min ago and loise has already crashed out.
guess i am going to get to work early tomorrow
4am according to www.formula1.com which means the pre-race will start on streaming at 3am hrmm I might get out of bed 15mins early and watch the first 40mins then go to work (I normally leave at 4.40am)
that justintv link posted last night isn't worth watching imo....extremely laggy
the 2 I posted are usually fine when they're working.
Ch10's coverage starts at 3:30 so worst case I'll just watch whatever they put on pre-race, which is normally filled with quali highlights and peter windsor talking shit about Homo for 10 minutes.
mmm toughest decision this week.....do I get up early to watch the race knowing that Hamo has 70% chance of winning WDC..............or do I get up to watch hoping for that 30% chancee of Massa winning this race AND the WDC.....decisions decisions
I'm standing by my, well promise, for lack of a better word, that I won't miss a minute of race coverage. I know there's not much chance of Massa taking it, but I'll still watch it till the end, and probably even the celebrations afterwards (whatever of it is televised) even though it'll be making me sick to see that flog take the title.
i'm telling you boys. it's all unfolding as I predicted. massa will win and homoton will choke. well he already has. he said he'd get pole and in the end got no where near it. i mean even trulli beat him ffs. trulli is a rolling road block! he'll allow massa to get a long way away, hamilton will try some kind of out there move on kimi or alonso who will of course be having none of it and put him in the wall. WDC to massa. :D
we'll see...
I love the way things work out sometimes!
Being in the traffic isnt good in any race, let alone one where most drivers dont want you to win the title and your main rival is at the front.
Lewis finishing 6th is quite possible, any mistakes, penalities or mechanical problems and it will be all over.
go mASSA! And the 5 other people who will finish ahead of lewis :D
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
