Nick, I'll be at the gym from 11am on Sunday, till late afternoon. Have a new guy lifting that benched 175kg last night in my gym.
He's a bodybuilder that recently won his first IFBB show. He is 173cm and 94kg. He is odd in that he squats 190kg x 6, deadlifts 250kg and benches 175kg.
Most BB dont train that heavy. He is very thick. I know a couple of the guys that compete against him, one NEVER deadlifts and only does 1/2 squats
Will be interesting to see how Michael goes in a comp, I reckon he'll go over 600kg first time out.
fck me... mental note, don't lift right after that guy!
damn I love a good burger... might actually have to clean the R... actually who am I kidding, that won't happen lol
Easy mistake to make given Dezz's physique :P
:wub:
In all honesty though, you have far more potential physique wise than I do..
Watched one of the resident BB'ers at my gym squat 300kg for reps the other day...deep.
Impressive stuff
So I'm going to be a test dummy and buy some of this albuterex just to see if its anything worthwhile.
My friend Is currently using it and he swears by it that his able to get so much more out of a workout then normal and his shredding as well
I daresay its not either.
But fark its worth a try and then I can actually tell people yes or no.
Rather then read off forums where people say its crap but they took like 4 scoops and went to hospital.
The net is littered with people saying its bad for you but they are taking more then what’s recommended
Military press is with a barbell behind the neck isn't it, or am I thinking of something else?
I never do it behind the neck, I have been told by a few trainer it's actually bad for you
how would that work though? the thought of it is kinda weird :yes:
No, that is a seated overhead dumbbell press, also known as the Arnold press in some circles.
"Military" means the exercise is done standing.
Edited by GHOSTrun
Because it's just a shit ton of caffeine and incredibly dangerous... you may as well just down 4 red bulls then hit a session.
Also, FIGJAM, you seem to be very interested in steroids lol. Why do you seem to have so much self pressure to get huge?
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
