60kg x 137... get faaarked! lol
I do 20 rep squats every now and then for a finisher... but I usually do them with 90-100kg and that's more than enough for me... I can run a whole basketball game without subbing too so I'm not what you'd call out of shape
try mixed, its the business for deads IMO.
Have tried, not a fan. Whenever I've had grip issues they eventually resolve through conditioning or by stepping up the weight. Not an issue for me now that I'm doing off the grounds!
In what way are you finding it harder? Energy? Time? Cardio? My workout is pretty volume oriented - I'd wager that someone with slightly stronger 1RMs would have a hard time getting through it...not that their workout would be a breeze for me either. My point is, there are a thousand different ways to workout and if you haven't trained for it, it's always going to be challenging!
As for deadlifts...I started off doing SLDLs and got up to around 110-120kg x 10 on that...but recently swapped them out for regular deadlifts, and am finding the opposite to you - 90kg x 10 is comfortable, because the muscles I wasn't using for SLDL obviously have some catching up to do. That and regular deadlifts give me headspins by the 10th rep lol.
Conversely, I would say SLDL requiring more back work and a greater range of motion for that muscle group = less weight than normal deadlifts for you.
How much you wanna wager, I'll bring down 3 guys that total 575kg - 650kg for you to take on, any workout, any exercise, any reps, you choose, make it worth their while though big fella
Mate you gotta stop taking what I say out of context - I said slightly higher 1RMs. Give me 1/3 of my 1RMs and I'll give you 137 reps too.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
