60kg x 137... get faaarked! lol
I do 20 rep squats every now and then for a finisher... but I usually do them with 90-100kg and that's more than enough for me... I can run a whole basketball game without subbing too so I'm not what you'd call out of shape
try mixed, its the business for deads IMO.
Have tried, not a fan. Whenever I've had grip issues they eventually resolve through conditioning or by stepping up the weight. Not an issue for me now that I'm doing off the grounds!
In what way are you finding it harder? Energy? Time? Cardio? My workout is pretty volume oriented - I'd wager that someone with slightly stronger 1RMs would have a hard time getting through it...not that their workout would be a breeze for me either. My point is, there are a thousand different ways to workout and if you haven't trained for it, it's always going to be challenging!
As for deadlifts...I started off doing SLDLs and got up to around 110-120kg x 10 on that...but recently swapped them out for regular deadlifts, and am finding the opposite to you - 90kg x 10 is comfortable, because the muscles I wasn't using for SLDL obviously have some catching up to do. That and regular deadlifts give me headspins by the 10th rep lol.
Conversely, I would say SLDL requiring more back work and a greater range of motion for that muscle group = less weight than normal deadlifts for you.
How much you wanna wager, I'll bring down 3 guys that total 575kg - 650kg for you to take on, any workout, any exercise, any reps, you choose, make it worth their while though big fella
Mate you gotta stop taking what I say out of context - I said slightly higher 1RMs. Give me 1/3 of my 1RMs and I'll give you 137 reps too.
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
