Interesting whats common knowledge on one forum were on is a mystery on another hey Nick lol
I have a clinical psycologist lift here, a weightlifter who just won Bronze at the World Masters in Ukraine
He explained to me that denial is our strongest emotion
Interesting
Do you think balancing on a Bosu or doing a random CrossFit death circuit of the day is going to get you vastly stronger? If so, then, think again.
What are your thoughts on BCAA supplements? I usually just stick to protein & creatine, but a few of my mates are recommending I hit up a good dosage of BCAA as well.
I currently take ON Casein before bed and ON Gold morning and post workout. It seems to already have a good amount of BCAAs.
Thoughts?
I'm an amateur gym dude, nothing crazy yet.
pencil-necked, polo shirt wearing commercial gym personal trainers
lol Kasko
Johhny - I bought a tub of Purple Wraath.
I'm not the HULK... yet..
purple lemonade is the flavour which DOESN'T taste like shit.
I have it in the morning as I'm trying intermittent fasting and therefore not eating breaky at the moment, and then during lifting.
I haven't noticed anything different.
As Mitch said, it tastes nice and I drink more water.
Edited by TTT
what are the benefits though?
Because from what I gather ON Gold Standard WPI has a good whack of BCAAs.. as per:
http://www.optimumnutrition.com/products/100-whey-gold-standard-p-201.html
Lol powerlifters and bodybuilders/gym goers... Can't we all just get along?
Not going to give an opinion on BCAA's as I haven't used them enough to voice a proper opinion, although I tend to think my stamina has been ever so slightly better during workouts in which I've used Scivation Xtend. The only supplement I have used now which I really appreciate is CREATINE.
Yes even I've put down creatine before, but whether a placebo or not, my strength in the gym has been higher than usual.
On another topic,
INTERMITTENT FASTING:
Yay or Nay?
Has anyone actually tried it long enough to provide some decent feedback?
TTT, how are you finding it so far?
http://www.optimumnu...dard-p-201.html
Unless your workouts are quite long, and/or you work out a few times a day you may find it won't have much of an effect if you're an amateur gym dude like you mentioned.
Tell your mates to stop being so stingy and try a couple serves of theirs before you potentially waste your money.
All protein powders are going to have bcaa in them.
The difference is with bcaa by themselves they are hydrolysed (broken into small peptide chains and individual amino acids) rather than being part of a huge long peptide chain. The benefit of that is they are absorbed faster because the body doesn't need to break heaps of peptide bonds with lots of different enzymes between individual amino acids to absorb them.
If you are interested in bcaa's have a read about them individually. Leucine is the most important, but it has been shown to work better in conjunction with isoleucine and valine.
Edited by Mitcho_7
Not sure what you meant by that quote :s
My sarcasm senses are tingling.
Hehe :)
I said a while back that I wouldn't recommend crossfit for someone pursuing outright strength and got torn apart for saying so. The same sentiment appears in a T Nation article and it's gospel :rolleyes:
Honestly though, unless your demands are high, whole foods are the way to go as some sources provide strong amino profiles.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
