Troy you muppet.. the deadlift for reps is with 100kg.
and you want to 1.5 times body weight making it 115?
but don't want to hurt yourself?
Please explain
1.5BW was just a suggestion (which for me comes to 109.5kg anyway). It was more to even the playing field. Perhaps work out what ratio of bodyweight the 100kg reps were for Joey and then apply that to everyone.
These vids are from 2007, weighed ~60kg
http://youtu.be/JmvveXH5lrw
Ps. do not deadlift like that ^ I have 2 bulging discs and I'm pretty sure the way I deadlifted back then is what caused them.
it's rare to have someone that can OHP body weight so I doubt you'll get people even able to do a single.
I certainly can't.
Pffttt...What is this ' I certainly can't ' rubbish.... you can and will ha ha..... People just need to add this as a goal.
If you are able to put time into bench press you will do well to train to press your body weight for reps.
Besides if you can train yourself to this goal , my bet is your bench will increase.
Not a proper strict press anyway
Sit down an do it, stops punters from hurting themselves initially before they do the standing version. Standing strict is just without the leg drive but, that is also a good version of the press worth throwing into training.
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
