Sorry but that still doesn't tell me why.
Don't apologise...
Not taking anything away from his effort, but look what happened when Ghosty reached the end of his rep range...his back and core wobbled and he stumbled around (forcing legs out of their previously locked position) trying to catch the last rep. A less...injury prone...way to standing overhead press, is one leg in front of the other and knees slightly bent. Done properly, you'll never move around like that.
Don't apologise...
I'm not apologising it's just a figure of speech.
Splitting your legs may take some pressure off your back as it stops you from leaning back as much. However, this has nothing to do with knees being locked out or not.
And leaning back has nothing to do with the exercise, it has to do with the person. If you are pressing overhead and start to struggle, you can either stop, start push pressing, and/or lean back to try and reduce the rom. Just don't lean back stupidly and you'll be fine.
I personally think flexing your quads gets more muscle fibres activated and provides a more stable base and core. And to do this your knees have to be locked out.
And to finish, the exercise 'military press' is done with legs locked out. If you are doing anything else you are not doing a military press.
Don't apologise...
But that was due to bad technique/overdoing it. Not because of the intended way to do it.
Edit: husky got me.
Edited by jangles
I'm not talking about him leaning back a bit, that's fine. I'm talking about the wobble in his midsection that is a result of pushing the set til failure and his back/core being the first part to give way at the sign of a struggle. With straight legs, your back and core take the full brunt of it, as that's the only place flex can occur. Bending knees slightly, gives you more control over the movement; allows you to use your leg muscles to maintain a straight back and regulate/reduce/counter wobbles on the Y axis when you start to struggle.
As for military press defined, in it's strictest sense I'd agree with you...but people do it sitting down and call it that, so as long as you're not driving with the legs when splitting, I don't see the harm in a slight variation to prevent injury when lifting heavy.
The military press/strict press was a lift that was done at the olympics. These guys were pushing 200kg's, and they had to have their legs locked.
Doesn't matter what people do or what people call things, the military press is done standing, with legs locked. It's not made up gym rules, it was a sanctioned olympic lift.
If you want to military press, stand up, knees locked, and don't bend your back too far. If you feel you are straining your back, stop the exercises and/or drop the weight. Work on your core strength and lower back strength.
If you just want to overhead press, then doing whatever way you want. Bent knees, split legs, sitting down, upside down....who cares.
I said I agreed with you about the definition of it? I just don't care if people think what I'm doing isn't military press, I'd rather save my back. I'm doing it for the exercise, not the title. If you want to talk semantics, I originally referred to bending the knees during overhead press movements, not military press specifically.
Anywho, I've already broken my rule of one argument + rebuttal, so time for me to let this one go.
I'd rather strengthen my back.
Change the way you think Birds ;), if something is weak then make it strong, don't avoid it.
/gah simon beat me to it
Edited by GHOSTrun
Current stack:
Synthol & some horse hormones that I got from some bloke who wanted to keep his name secret so he called himself chestbrah.
Seriously, eat clen and tren hard. Ty men.
Strong post to join date
Strong AVI
Strong username
strong everything
This guy.... uses every damn quote that annoys me from Facebook pages
Edited by Dani Boi
From Facebook pages...? L2internet my friend. I loved these quote UNTIL I saw them on Facebook, at which point all the little social media faggots cancer ruined them.
I'm sorry for offending you Tom.
Strong AVI
Strong username
strong everything
hehe ty men.
Some people just want to see the world burn. I'd agree with you there though, almost everything from 4chan (/fit/) included it's hilarious. You would NEVER hear anyone talk about "epic" things or "memes" circa 07.
Yes your bulging discs are doing a great job of that. Strengthening doesn't fix bad form, correcting with proper technique does. I'm not avoiding any weakness here...the back and core get worked just as much in my method, only less susceptible to injury because it's a stricter movement.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
