also just read the Stronglifts.com 5x5 workout and diet.
he is of the opinion that all supplements are b/s, eat whatever you like, train hard enough and you'll end up with a good build.
Pretty much..... if it's illegal it works by definition . That is why it is illegal ,boosts performance significantly over what genetics and diet are able to achieve naturally.
You can achieve amazing results without supplements if you train properly and hard enough. Peoples genetic potential is usually far beyond their diet and training effort in most cases.
Edited by rev210
so in other words NO BLOODY EXCUSES!! ;)
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
    • I would tend to agree, especially based on the transfer oil being completely cooked by the sounds of it. I bet it was serviced every 5,000km... Which probably worked out to once every 15,000 real kms...
