was recommended to be by Trent at PTC to mix in with some cardio to achieve some goals which are not just strength related but more total conditioning and health and fitness
if that at all made any sense
nah he probably like 83kg, shredded doe and tall-ish always wears belt and red singlet. youll know if I pointed him out - stays for hours lol
Edited by UNR33L
If you genuinely hold any of the top spots at your gym, it's probably a shit gym =\
No offense at all, as I think you've done great, as have many here, but I'd hazard a guess and say that most of us are average, maybe towards the upper end of average lifters (not me, but some of you) at best.
Unless we have some solid comp winners here I don't know about.
In my gym, I'm the top lifter.
Edited by ActionDan
I think I know what you are saying...
Our gym is a "Genesis Fitness Centre"...so top spot in anything is a title easily taken, compared to say, a lifting gym. I'm yet to see someone lighter than me deadlift more at my gym. I wouldn't care if someone did; would actually find it interesting and enjoy the competition of it, because right now I have to leverage my motivation to be stronger off of people at other gyms. And I did win our deadlift comp down there, so there's a degree of truth to what I said...but in the end it was just a joke, mostly referencing appearance/aesthetics because you mentioned "checking out" guys.
inb4 some tard doesn't understand this / read it properly and points out that someone at PTC is 10 years old 62kg and can deadlift 400kg.
My point was left about the lifts and what "spot" you have and more about the comparisons to other guys.
Like you said, there will always be a 10yr old at PTC DL'ing 400kg (I laughed at that).
So "spots" in your gym really mean jack, unless it's just a way for Leigh to pick up dudes?
Edited by ActionDan
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
