I do bench press...
Day 1: squats, pull-ups
Day 2: deadlifts, bench
Chuck bicep curls at the end of day 2 if you like. You don't really need them if you're doing enough deadlifts.
That's about as complete as you'll get in the shortest time. I've got plenty of time on my hands but after trying this for the last 12 months I don't feel the need to bother with anything else. Keep it simple, stupid!
I have no idea what starting strength is...this is just what my program evolved into post shoulder injury to accommodate everything with as little shoulder interaction as possible. It started as a leg program in my days of not being able to move my arm much without pain, then evolved to include pull-ups and bench as the shoulder recovered somewhat.
Figjam, you could do 5/3/1 with minimum assistance too.
Starting Strength is
Workout A
3x5 Squat
3x5 Bench Press
1x5 Deadlift
Workout B
3x5 Squat
3x5 Press
5x3 Power cleans
Workouts A and B alternate on 3 non-consecutive days per week.
Edited by bozodos
Don't wanna argue with a famous program, but the OCD in me doesn't like the idea of doing exercises unevenly like that. I like the spacing of mine, the simplicity, the lack of overlap, the fact I'm in the gym 4 days a week which perfectly fits into the working week with a rest on Wednesday...the fact I'm stronger in all exercises just doing this for a 40 minute session than I was when I was in the gym for an hour and a half each time. Will be doing this program for a long time methinks.
I get minimal results, every month I only put a extra 2.5 kg per month on my bench and OHP and 5kg to my squats and deads, as I'm bad with math I don't know what that will equate to after 12 months.
Hang on, that's 30 kg for my bench and press and 60kg for my squats and deads.
So going from that and without having to do a deload due to stalling that would be going from my current 1 rep training maxes of 130 to 160 for bench, 80 to 110 for press, 180 to 240 for deads and 145 to 205 for squats.
One of the guys at work lifts competitively and has hassled me to have a go, I'm thinking of training smart for the next year and a half and then having a attempt at a comp, Ill be 50 then so it is a good motivational tool for me to use.
Slow and steady for the win is my new mantra.
I'm all for adding weight that way, slowly and steadily, but have to be realistic too...if you have a 160 bench within 12 months, up from 130, and haven't jumped on the juice I'll go HEY! Well done.
Having a structured program where I walk into the gym knowing how much down to which sets of plates that I'll use what I'll lift is the best IMO. I like having a squat assist on my deadlift day, a deadlift variant assist on squat day, and a bench assist on OHP day.
I do have mates who can't stand doing the same thing for more than 3 weeks in a row though, so I guess its horses for courses. Naturally I'm now stronger than them.
If I stall then I will deload on the exercise I'm stalling on, if I don't progress as fast as the program states then so be it, BUT, the program has a solution for it, deload and then keep going up.
My next goal is to push or pull what's written in my training log, soon I will be doing a PB for every exercise, even if its only 2.5kg.
I'm not looking to be the guy who lifts the most at the gym, I'm taking this as I do with my car and my job, with time and hard work I improve, when I stall I find the reason and fix the problem.
A good quote from Starting Strength is "3 steps forward, 1 step back".
Either way Im getting stronger which is a win.
Boz I 100% agree, lots of guys at the gyms I use focus on curls, forearms and calf raises and have no structured programs, they may have some "peaky" biceps but they are weak as piss on all the compound movements, they are the same guys dropping the weights when they dead 100kg because they don't have the strength to lower it.
Provided you have the genetics , diet and rest you should have a red hot go at this over 12months.
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
