Fair enough. What works for me is BBing hypertrophy combined with an upper body an lower body strength day:
Monday - Leg Strength + Core (deads and squats)
Tuesday - Chest (hyper.)
Wednesday - Shoulders and arms (predominantly lateral and posterior delts)
Thursday - Leg Hypertrophy
Friday - Back
Saturday - Upper Body Strength
BUT, this is just what works for me right now :yes:
AND, I change this layout every 4-6 weeks depending on other factors, next could be more strength dominant
Morning brahs.
I'm going to start my first foray in to fitness, initial aim is 5-6km jogging through hiking tracks 4 nights a week followed by some at home lifting/crunches/squats etc. I've worked an office job for the last 7 years so I figure this will be a good aim for first couple of weeks.
Is there some pre/protien/mix of supplements I should be looking at to help maximize workout?
If you're not already a runner 5-6ks daily might be a stretch but your body will tell you.
Get good shoes, and I mean trail shoes likle Salomons or something with Gortex lining, not Nike's they will get shredded easily.
As for Supps, basic WPI/WPC and some creatine will likely cover off all your needs as long as you're eating a relatively decent diet.
You can assess how well you recover before deciding if you need them as you'll mainly want them for recovery given your aim is fitness and not big strength gains.
Oh and as a fellow desk jockey, you're going to want to stretch a fair bit, it will help with everything. Sitters like us tend to have poor glute/hammy/hip flexor movement.
Edited by ActionDan
How's your DL'ing going Birds? You had some solid momentum at one point.
Average mate, I hit a bad bout of tonsilitis / yeast infection and lost 20kg off the bar from taking a couple weeks off. It's taking significantly longer to get the strength back :(
Back on the rise again, though. I think last session I pulled 100 x 10, 140 x 8, 180 x 1, 170 x 3.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
