Im looking at taking my car out to the track. right now i am performing the neccessary upgrades to ensure i can race.
I saw that i need to have a secondary bonnet restraint. What do you guys use?
I have a standard bonnet and i think i will look like a wanker if i put bonnet pins on it. Anyone got other suggestions?
Cheers
https://www.sau.com.au/forums/topic/201649-secondary-bonnet-restraints/
Cheers
Does it state that its needed for a stock bonnet?
The OEM latch is unlikely to fail, and if it does, the safety catch is also unlikely to fail.. if you see it quick enough.
I wouldnt be worried about a secondary catch for an OEM bonnet. Unless it clearly states it IS required for an OEM bonnet too.
Iv been track racing for years, and the only people i know with pins are those with CF bonnets where the catch isnt bolted to anything structural, IE the fiberglass skeleton.
Also, out of the many many many days i have been to i have NEVER ever seen a bonnet come unlatched or fly open.
The odd muffler fall out the ass, fuel tank straps coming off and blown motors/boxes, even an engine mount bolt working loose and flying out under the car... :D but never a bonnet!
Edited by gotRICE?
I've seen many carbon fibre bonnets come off actually. It's really hilarious to watch (not for the owner of the car though).
They often smash backwards and smash the roof and the windscreen. Sometimes they crack badly and bits of the bonnet flies off.
Most of the track days ive scrutineered, a secondary bonnet restraint is necessary. Lots of people hook an old belt from the bonnet frame and clip it down through the bumper or so. Another way is with a small chain and a shackle/caribbina and hook it onto the radiator support.
basically it depends on the Supplementary regulations for the event you are entering. If the Supp regs dont say anything you don't need a secondary restraint unless it is full on racing (schedule C requires secondary restraints for non road regstered cars)
Most events dont need a secondary restraint for modern cars
1 question though,
With using a belt or the clips etc, what if theres a fire under the bonnet?
Be a bit hard to get them undone in time?
mind you though if there is a fire Id be out quick smart! but if a small,little fire started?
Despite the dual catch system std on modern cars the track days we do with the WRX club here in Vic state you need one. There are lots of ways you can do this.....bonnent pins are fine with a std bonnent, others use a belt strap fitted to a suitable spot and I use a wire cable attached to the frame of my bonnent which hooks to the radiator support.
  • 5 months later...
my advice is buy one of these babies. http://www.initialdrift.com.au/forums/view...074&start=0
cost about $25 and make sure you ask for it to be sheathed with the rubber heatshrink (stops it scratching up stuff). easy to fit, just need to drill a hole.
now that I've bought mine I just keep it in my helmet bag with licence and helmet etc so that I never forget to take it to a track day/sprint/whatever.
I'm surprised you need a secondary restraint for a skyline, its certainly not required in the CAMS regs (late model cars don't need an additional restraint). Unless it is requried by the supplementary regulations, I haven't seen them
Yeah some events now are starting to require them now even for late model cars. Up till now later model cars with an un-modified 2 stage factory catch have been ok, but for some reason of late it seems they are moving towards making all cars use a secondary restraint. Even a recent drift day I attended required all cars to have one and that is classed as a non-speed event!
Still for $25 and 5 mins drilling a hole it's not too onerous. :P
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
