Dont forget that mnay of the titanium exhausts only run one muffler where others run two. So one less muffler also helps....and the few single muffler tiutamium exhausts i have heard sound great...but my god they are loud. With speed events typically havign to still be under a certain db reading....you could find yourself even getting kicked off race tracks. Duncan and SK need not worry as State rounds are typically no noice days...but us club guys? Expecially in Vic last year where i got several warning that saw me driving around off boost just gettign my eye in for a single session where i gave it hell :D
  • Replies 42
why don't they make exhausts with the V-band type flanges now? trust did make one before like that, and it's awesome. easy to fit/remove. seals well, no pesky leaks. I guess cost is the only downside, but it's not like you are going to have 10 bloody V-bands.
Maybe check here:
http://www.trust-power.com/01exhaust/pe_Ti.html
They are supposedly all good to the JASMA standards. Click the Nissan button & have a look at the pdf. My kanji is compelte rubbish so the columns may mean anything. :D
Yup... They're all 5.0 - 5.1kgs for the cat-back for the PE Ti-R and 6.7 - 7.1kgs for the PE Ti cat-back for GTRs.
Roy, What "speed events" are you talking about exactly?
Surely there wouldn't be any noise restrictions on private track hire days and private practice days? I just ordered a "bloody loud" Amuse Titan R1 exhaust which I fear will be very loud, and I don't want to run the car with a silencer :)
Brand and specs on this one? Titanium cat backs are very light, but not THAT light.... 5.x kgs seems to be the norm from what I've seen.
specs unsure of..bought of the forums..it does not have 2 mufflers its straight through into 4ich cannon.he said it was 3.1kg and well it felt light so i didnt even bother checking...2kg who gives a rats anyway...
sounds wicked thats alli cared about
deal Gary, what size do you want, and how long?
Andrew - yes there are noise limits at some tracks on some days. All NSW circuits have permanent noise meters but they often are not manned. The hillclimb tracks often have a noise meter, it depends on the neighbours (for instance MG Car Club at Ringwood and King Edward Park). They normally specify max noise at 30+ meters away from the track - when you think about v8 sports sedans and supercars being legal most skylines are OK with a big turbo in the middle of the exhaust quieting it down
I have a 900 mm Trust Ti cat back on the R32GTST and it is almost 20 kgs lighter than the 3.25" Nismo cat back that it replaced, which is now on the Stagea. I have been looking (albeit not very hard) for a source so that I can make the cat forward section out of Ti as well. So Duncan, you find some Ti and I'll get it welded.
Cheers
Gary
thats one big system....900mm....zero backpressure with that puppy!
Is this an actress and bishop joke? :blink:
Obviously I would like 90 mm to match the back half. Length is tricky, 1m would be enough to do back to the joint where the wastegate pipe joins the turbine pipe. If I go any further than that (closer to the turbo) I would need 2 sizes, 75 mm and 50 mm. Plus it would need a lobster back welding job for the bends, which is very time consuming. To do the lot would require about 1 m of 90 mm, 1 m of 75 mm and 1 m of 50 mm to cover it.
Cheers
Gary
  • 1 month later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
