  • Replies 569
Posted Images
So I trundled across the road from work to have a coffee with me ole mate Dave this afternoon, and what did I stumble across?! A part media-blasted 34GTR. Wonder who's that might be :D
Gee that rear bulkhead has had the "mega-mod" :) Lookin schweeeet!
And sitting in the same spot 12 months ago.... whadya know... another blue 34 :)
haha!! small world isnt it!!
he is a master isnt he!
we will have to catch up after targa ben!
but i hope to be coming down to spectate for the first two or three days and see how things work. so will be seeing ya there too
I will be heading down for the weekend, hopefully Kel and the DK 32 are still going strong. Let me know if you are down there on the weekend we can catch up for the long awaited beer or 3
dont forget your carbon widebody and kagotani front bar and diffuser are finished and packed into the largest cardboard boxes known to man!
don't wanna bring a set of rims back in there for me do ya? assuming thats in Japan at the moment that is...
haha, sure is! :nyaanyaa:
He's unbelievably good....... just don't tell him, the price will prob go up! lol
For sure, will be excellent to catch up on both counts.
sorry mate, it's chockas. that pics was taken with only about half the gear in there.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
