Most of the coil overs I have found so far are only for the non ARX model. ie, they are a lower ride height. I would like to keep the ride height and get better handleing which I am told is possible. The problem with the Bilsteins is that they are only made for the Jap market and what I am trying to find out is if the valving is set by Japan or Germany. If Jap, they are likely to be very stiff, if German they should be a lot better.
Any competent shock shop or particularly anyone advertising as Bilstein agents should be able to revalve Bisteins to your requirements. I was luck enough to get some (4) second hand Bilsteins supplied and completely rebuilt for NZ$600
  • Replies 41
melb guys - for suspension try damien at suspension city 41 provost st nth melb ,039329-5133 , cheap bilsteins , cheaper than the aust distributor
can organise all info about spring rates , bound & rebound of springs and dampning rates of the shocks, regards alan. :D
Cheers for that.
I will give Damien a call & see what he says.
No harm in asking eh?
I got my Bilsteins from www.northshoreprestige.com.au.
I must say they are the best aftermarket shocks i have used on the street in terms of ride comfort. Totally eliminates that floating feeling lol.
Yeah I know.
I spoke to Ben months ago about possibly getting a set... Higher priorities in life got in the way and now he cannot source the BTS kit!!!!!!!!!!!
damn, blast and bother, I say!
  • 1 year later...
I'm going a different route with suspension.. im going those KYB damper kits first then trying different lowered springs. i dont want hard as rock coil over handling but i dont want it soft as either.
Should arrive next week, tell you how they go. :)
The intercooler kit description is wrong also.
there are 2 blitz kits available for m35's .. blitz CS , and blitz SE both kits are made to suit for m35's ive only heard of one being used on this forum by someone on the gold coast. not sure of its fit or placement but i heard theyre good.
but expensive ..$700-900~
P.S everyone i speak to in the suspension field says dont put coil overs on them.. so im gonna go against the grain. i'll tell you if these suspension people know what theyre on about or if theyre just full of ^$%&$ regarding the m35's ride..
Edited by PetroDola
WTF? :)
Coilovers are one of the best things you can do to your M35.
Edited by iamhe77
everyone i talk to says ityll make the ride bad.
but on the same token they've probably got no idea in the variation of coil over.. and the hardness to everyones real experience here with m35's.
my front shocks are fragged.. and suspension friend is saying KYB's will do it justice and some nice springs and not coilovers.
so im gonna give it a go. see how the ride goes. if its still too sloppy ill go for coilovers.
Nah mate, all depends on what you use. I'm using BC, HR series, not harsh or hard, just firm and controlled. On softest setting (of 30 steps) it is beautiful, every click makes a noticeable difference. Best part; set the height exactly where you want.
Thanks for the info dale
Wasnt sure which BC series suited. can you tell me where you got them from? :down:
Should arrive next week, tell you how they go. :down:
i have the KYB kit and they do ride very well not to hard a ride, just firm
Wasnt sure which BC series suited. can you tell me where you got them from? :(
I bought mine from a trader on ebay, but justjap would be your best bet. As for low, you could use it as a grader fully dumped. :down: . Seriously, I'm at about 110mm at the bottom edge of the front bumper lip, could go at least another inch, inch and a half.
Would anyone with any of these kits "Bilsteins / KYB / BC's etc" be happy to chime in with part / kit numbers?
I'm trying to source some replacements for my Stag but it seems no one in NZ has heard of the M35 and i keep getting quotes prices & parts for the C34.
PS - Tis only for the VQ25DD (non-turbo model), but i doubt there will be much variation if at all between the turbo & non-turbo models.
Cheers in advance
Kev.
BC's are available in the link above. http://justjap.com/store/product.php?produ...=457&page=1
So you could get that part number and take it to any BC stockist and get a price.
Autolign can get Tein coilovers. As can TopTown, Mag And Turbo etc. Autolign will be your cheapest bet though.
Why anybody would take am M35 to a shop for advice I have no idea. Been there done that, expensive lesson. Post up you questions, there is always somebody that has gone down that path already...
BC's are the go... :cool:
Yeah, well i'm quickly learning this the hard way haha.
Cheers 'Jay' and Scott for the quick replies.  :cool:
found this site the other day.... http://m35stagea.info/forum/....maybe see if you can find anything there!....or post up you findings.
:ninja:
Perhaps if your link to M35 Stagea Info actually worked...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
