spose i wasnt actually at vilis, lol.
spotted damo (i think) out past modbury near some random blockbuster and takeaway joint about2 hours ago, i was heading out as you were heading in, gave a wave.
Did not spot. Incognito? I was keeping my eye on that supra, gave me the death stare after he came out of blockbuster :down:
sooo many imports around the bay area around 7 to 8ish. Burgandy 32 parked near the watermark\buffalo, large sau sticker on back. Silver 32 with bn kit, rims etc parked down down side street at bay. shannon (sx appeal) and kelly (dior 33) also parked down there.
Did not spot. Incognito? I was keeping my eye on that supra, gave me the death stare after he came out of blockbuster :cheers:
haha, yeah, noticed that guy too, he looked happy. was driving maybe 5 metres in front of you, made a bit of accidental noise on the way out too.
flick, im pretty sure that was actually a dark blue/black 32 with big SAU sticker on back window, parked at the wigley reserve parks.
Also spotted Lyndon in his 34gtr down bay earlier today, white wheels look awesome.
Saw that 32gtr pictured a few posts up too, had another 32 infront of him driven by a chick with a few different coloured panels.
And a burgundy 32 with plates HR32 on anzacs twice
Couple of other random 32's and 33's, so many out today, made me wish i still had a skyline to street around in.
Spotted a maroon r32 as I started my run into the gorge about 8:45pm tonight .. gave a quick wave, but as we were going around a corner in opposite directions, I'm sure they would have missed it .. haha ... mostly pretty quiet tonight when i was out ..
oh, haha my bad. Was a burgandy one parked there anyhow aswell.
seen a dark blue shelby cobra(replica no doubt) with a really high roll bar ruins the look a lil
its the same 1 i seen about a year ago, owner looks majorly old school (like 80s) and he still gives it some gas, bit weird to see :P
spotted damo out the front of my house lol
and spotted the same silver r33 that keeps going up and down my street again, and again and again
also spotted a black r33 go past too lol
^ whooooooooo damo n cara :P just messing
spotted backfire louder than your average gtr come out of my dato and a overheating incident :P left me stuck a lil while on the side of the road.
1st time my cars eva left me stuck for a bit in the 8years ive had it :P seemed alright after though
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
