spotted what looked to be DSTROY's display pic cruising through the hub at like 10-11 last night? although i did have my beer goggles on lol
Your right that was me driving past the Hub in the Ceffy, i was on my way back from a bit of a test session in the hills :banana:
got talking to a pretty cool girl who works at all clutch and brake, owns a red 33. seemed to know her stuff. at about 3.10pm.
That would be Jo and her family runs that place, 33 was her dads
Spotted a yellow stag today, S series plates out in Gepps Cross at the lights out from the go carts, so much better there then the Richmond go carts. Also saw a green stag, was an aqua colour, cant remember where, was out north somewhere, may have been south road... Was heading south.
Also a clean as siilver 33 GTR in torque motorsports yard, very nice.
spotted a black r32 gtr crossing the bottom of the freeway headed to magill area at 10:32pm stock exterior sounded nice
and also a r33 gtr what seemed to be midnight purple or black not sure
with a left rear pancake tyre
hahaha :D
looked mad though
also sounded nice in the tunnel
:woot:
Edited by Pepsinator
spotted a red stag p plater and a white 34 on moana beach last night about 6
yeh that was me and my mate, pretty sure i spotted you at the beach again last night to :/
got a wave from a pearl white 33 4 door on commercial road about 4:30-5
yesterday on my way to and from the beach i seen a white r33 with gtr wing heading down towards port adelaide.. seen a purple r33 in craigmore. seen a silver r32 with gtr wing at the fitness centre on main north in salisbury. seen a white r34 with gold rims at city dismantlers, and i cant remember the others.
spotted a MINT white dr30 this morning parked out front of my work on Pirie street. had plates KDRJ30 or something like that
seen that on rundle st before
its got twin bride seats i think
so hot <3
Your right that was me driving past the Hub in the Ceffy, i was on my way back from a bit of a test session in the hills :P
sweet i was ahh walking.. with a mate near the shops looked good!
spotted what looks like Morris in his r33, bright blue on beach rd a bit ago
white gtr r32 at BP beach rd
yeah that would have been me :) didnt see ya?
yeh that was me and my mate, pretty sure i spotted you at the beach again last night to :D
cool yeah i saw ya there again lol its bloody hot
Spotted a Bright blue s1 33 and Bright Yellow s1 33 in the space of maybe half n hour up in morphett vale area!
Both looked awesome in the sun!
:D
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
