I always see a grey R33 GTR with lots of nismo badges in the Findon shopping center carpark. Has vented front-guards and the rims don't quite match up with the guards, but otherwise seems fairly tidy.
Guessing someone on here?
Yeah I see that 33 regularly also Jenna. So many nit wits in that carpark I've seen some very questionable displays of parking haha!
On edge that could have been me you spotted grange rd I turned onto south rd. Just got the car back with my greddy induction installed... I realized I got usernames mixed up the other day it must have been zed x I saw early in the morning a while ago. No wonder you were confused haha
I've been in that carpark pretty much daily for the past 6 years. I've seen some of the worst parking in my life there. I try and not park near people if I can help it. Half the cars are parked across lines, at angles, and other nonsense. It seems worse on particular days of the week too. Think it must be pension day or something ..
True. Alongside grange rd is good cause people are too lazy to walk 50m and the parks are wider. I always try to pick a park where only one car can be next to mine so there's half the chance of random damage.
Prob was u, thought it was anyway.
I know that 33 too think he got inspiration from my car but failed miserably in execution, an it aint a gtr
You spotted me? Hmm when was this lol?
I did spot a nice silver 32 gtr pulling onto churchill from regency earlier on this week, was around 6am.
About a week ago on holbrooks rd, about 6 am aswell. :action-smiley-069:
Was most likely me you saw on churchill, part of my daily commute. I love dropping it down to 2nd coming down the bridge and hugging the slip lane onto regency already doing 60 that time of morning (not while the roadworks are there like they currently are)
Ah yea I thought it might have been you ;)
Haha yea you were definatly flying through when I spotted you. Sounded amazing coming into 2nd under high revs :)
I pass through there around 5pm, some people are so slow through there. Just sit in the intersection like a douche -.-
spotted plenty of skylines today in the ne suburbs -
silver 34 gtt sedan, looked very stock @ repco modbury around 10am
black r32 with big wheels on NE rd st agnes around 10:30am, pretty sure it was a GTST
navy blue r34 gtt sedan, looked stock besides exhaust, in front of me around the same time as above
white 33 gtst near TTP
black 33 on lower NE around midday near highbury tavern
and a black 34 gtt coupe on lower NE coming out dernancourt shopping centre around 4:30
Near tapleys/ grange intersection on grange road at night
not there it wouldnt have been. thurs and fri nights i was down around semaphore / taperoo / osborne area (military rd, lady gowrie drive and victoria road)
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
