Spotted RPM510 at the new On The Run in Reynella - pretty sure its a members car?
absolutely awesome looking datto - those 15" meshies & black front splitter complete the package ;)
Must of been a similar number plate cos I have stock rims and no splitter.
Edit... Just had a look at AJD pics, that car has the plates REV510
Edited by DSTROY
Spotted DC GTST last night down at harbourtown maccas
I was passenger in my mates red AU XR8, gave u a wave from the passenger seat. Both my ford owning mates that dont normally rate "ricers" thought that your car sounded tough and looked stealth :)
a guy in a flip paint s1 rx7 being a tool while doing laps of hindley and rundle st... and 2 hours later crashed into a gutter/pole
bahahaha, was that the green one during the day? I saw one on pultney street. Here's a pic.
baaahahaha yep that was it! you mustve been there about the same time as me...
when i saw him 2 hours earlier, he was giving it some stick past the cop shop in hindley street, i turned to my missus and said "what a dick, i'd defect him". i guess his end result was better hahah
but now i think about it, i couldnt see the driver or passenger near the wreck. maybe it was stolen?
Edited by Deep Dish V35
Ahhhh that makes sense! Was with a chick friend and we looked at each other and weren't sure if you were waving at us or someone behind us (looked around like meerkats behind us). Cheers mate :) Hope you guys had a goodnight, we were there till about 2:45am 'chatting' :P
STOLEN!!!!!!!!!!!!!!! GUYS KEEP AN EYE OUT FOR A WHITE R33 SKYLINE SERIES 2 (REGO - XLF 351) WITH 18" GOLD DRIFT TEKS, CUT FRONT BAR, DRIFT PIPES, TINTED HEAD LIGHTS, 15" ALPINE SUB!
CAR LOCATED IN WOODCROFT AND HAS BEEN STOLEN AT 6AM TODAY!
:laugh:
yeah, we cruised past back to my mates place about 2:30, and you were still parked there LOL
:laugh:
I was really on highway patrol :ph34r: lol 'Was' going to head through the hills...obviously didn't progress....
In regards to that stolen R33, any chance it was seen down Lonsdale Highway/Brighton Road? Seen something very similar to that while on the way to the workshop this afternoon about 1:30pm :/
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
