Yes Cerbera zeds don't rev quite as high although mine revs to 8500 compared to a built GTR prob 9500, peak power that day with mine that day and more revs was 438rwkw, although with stock rods and they bent. Cheap motor with mostly OEM stock parts apart from pistons, since used Scat rods and all good.
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3674357
  • Replies 241
Can we please be put out of our misery!! What's in it!!
All i can figure is that it might have a higher compression ratio than most people might think, and high lift but not too crazy duration on the camshaft, mixed together with some careful cam timing; for a nice recipe..... High comp gives good off boost power and would build response more rapidly...
I'm out of ideas, please tell us the answer, we wants to know......
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3679883
Bens been perfecting this recipe for years.... I doubt he will just "kiss and tell"... I know I wouldnt (but DAMN I wish I knew).
Go Race Pace.
Edited by Antimatter
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3680268
  • 3 weeks later...
P Zero Corsas have to be one of the worst tyres i've ever tried. Get some R comps on and you will feel the difference.. lol
Not sure what your smokin dude but they are a R comp tyre, they're not quite up to the standard of RE55S but they are much better than any street tyre out there...
So tell us about your 'experiences' with tyres, which have you tried and which would you recommend???
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3733320
  • 1 month later...
its sleeved to 86mm
if anyone is looking for a full long block everything except for timing belt area covers and cam covers. i still have one sitting here is a virgin r32 gtr block with standard head which came out of a car with 67000kms on it i bought it for a project but ended up using other bits....
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3857538
+ the rest probably. With all other parts needed for the build...
I meant 20k for the engine. I bet the rest is almost 20k too.
this is running a big single on a rb30 block gtr head.
close, except the rb29 is 447KW (612HP) and it's running on pump gas, not race gas
Edited by Tao
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3857598
I'm coming into a bit of money later this year. I just want to know how much I need to set aside. I bet it's approaching $20k
Double it and you might be getting close to the total figure needed to get these results..
But I still doubt it will be enough... :P
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3858027
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
