Was driving along beach rd to work, and you could see the road had the rainbow/oil slick look to it (first rain after a big dry). It was SOOO SLIPPERY!!
On a gradual bend, that you could probably take at 100+ in the dry, at 60, a slight bit of extra throttle and the car was stepping out (not even on boost). Even straight line, normal acceleration from the lights was struggling sometimes.
I've got plenty of tread left and $$ tyres, plus other suspension mods so i know it wasn't the car... it was just damn slippery
so PLEASE take it easy out there. I saw one accident on the way in, but there are surely going to be more floating around on the news.
-chinny-
https://www.sau.com.au/forums/topic/206942-its-fcking-slippery-out-there/
yeah my ass end was all over the place on the way home. heard there were a few crashes around.
amazing how it can go from hot dry 35 degrees then the next day 22 rainny cold and wind. Only in Melb :P
Edited by jake33
I was almost sideways coming out of my driveway this morning. I turn onto a hill and in the rain its almost impossible to accelerate at a regular speed without loosing traction which makes it a pain to pull out into traffic. Think I scared a lancer just a bit this morning while I was driving to the train station in suddenly in 2nd the rear started sliding out in front of her.
haha.. yea i almost got into a bit of trouble. coming out of Forster Road on to FTG road, I had a Burger in one hand and dart in the other, 3rd gear and my back and was steppin out, and I hardly had my foot on the throttle too.
If you cant keep traction on a wet day you shouldnt be driving.
Amen. Bout time someone said it.
I think people feel cooler if they can't keep traction....My daily has 250rwkw and I can keep it in line with little to no effort.
Learn to drive :P
it's got nothing to do with being a hero, or not knowing how to drive.
all my point was that it was exceedingly more slippery than any "normal" wet road, and you could see the oil sheen on the road, and the extent to which it was visible, was NOT normal.
all i was trying to do was give people a heads up in that the roads (well, beach rd at least) are A LOT more slippery than they are normal... and if that means someone misses an accident because they gave more room between them and the car infornt, well, the thread has done it's job
there were lots of crashes - and i was listening to AM radio on the way back from the train station. The Lindi Burns was saying something like "as soon as it starts raining, people forget how to drive"
How true it is. there was one ass wipe this morning who was cutting in and out, wouldnt let people change lanes etc......what an ass bandit
i know to be very careful in the wet in my car and i was taking it very easy around every bend and roundabout. i was doing under the speed limit and had a slight curve in front of me so i only had to turn the wheel a little bit. then the back end kicked out a little bit i pretty much shat my pants cause i wasnt ready for that to happen, i looked behind me and it happened to a couple other cars so there must of been some oil there it was pretty scary considering im not really used to rwd cars, cause i used to drive a subaru and you never cared when it rained.
it was filthy outside today, i was slidin everywhere on shitty nankangs, was enough for me to get a new set of yokohama r1s best tyre ever for me lol.
i expect this would only happen if you floor it in the wet ?
yeh i would also expect this cause i can keep my car straight with 200 + rwkw and got the worst tyres imaginable on the back
and they are stretched to
my VL wagons fully sick in this weather.. makes me feel like its got 500HP... sick
:rofl:
bahahahahaha
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
