DO DAY?
41 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 298
Posted Images
Oh yeah and thats all i suggested!!! sitting down and eating!! dont worry about it just keep it the same i dont care no more anyway do what you want i wont suggest anything seeing its just going to be shut down!!!
Al, let me know if you end up going ill come down as well.
I'll try but i have no access to a computer during work hours, so i may not be able to post up if i can make it or not. On the other hand i may finish early and let you know; my job is pretty random like that :cheers:
calm down im on your side :cheers:
yea i went once, dont plan on going again unless a cruise or somethin is organised. dont see the point of it
thats the point..if you arent doing anything why bother stay home..get out of the house haha
i cant be arsed cruising..i can be arsed meeting up in a carpark and standing around talking shit though.
go figure...maybe its a guy thing haha
D@MN i forgot about this last nite!!
Cant make it for 2 more weeks, barge is going in for paint.....again, hopefully for the last time :D
If ppl wanna cruise why dont we suggest some places? Keilor rd may be quite quiet on Tuesdays, maybe hit there for some coffee n Mars Bar cake....mmmmm Mars Bar cake!! :D
Or maybe hit that Souvlaki Hut down Taylors Rd?
Plenty of parking and outdoor eating area if its noice weather.
hmmm think i gotta go do a panty, i mean pantry raid!
supose if there is a meet up there will always be a little cruze around of some sort..
dont no realy never been to a meet, but i dought week after week yous meet up and talk
about the same shit over an over again, with out even goin for a little cruze.. or am i wrong lol...
Cant make it for 2 more weeks, barge is going in for paint.....again, hopefully for the last time :P
Kelly let us know if you go to a cafe and we'll be there :D pfft souvlaki.. maybe if I wanted food poisoning... maybe I'm just paranoid caus I remember Sydney Rd Souvlaki..
Just don't do it on the same night as the SAU GM (every 3rd Tues of the month)!
yea, lol...i was crawling around and at the same time i was trying to see who it was! Wouldve been funny from behind, looking like a drunk, lol.
Steve your a laugh i came next to you and you top mounted the roundabout LOL why didn't you come????
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
