How many people keep their airbags in their cars for motorsport? Has anyone else heard of them going off for no apparent reason?
The reason I ask is that I was up at DECA on the skidpan on the weekend and the airbag in the car I was driving deployed for no apparent reason (I didnt hit a cone - I was pretty much driving straight but was only travelling around 40km/hr max). Its got me thinking how bad that would have been if it had been in a high speed section of a racetrack rather than in the middle of a concrete skidpan doing low speeds because I can tell you I was out of it for a few seconds after it happnened (was in an R33 GTR). So I'm wondering if I should get rid of mine ASAP?
https://www.sau.com.au/forums/topic/207577-motorsport-and-airbags/
Joises! Woulda given you a fright I bet.
I can't see why it would have deployed (issue with poor previous accident repair maybe??).
For rallying we have to de-activate/remove all airbags and this is checked at scrutineering.
I'd certainly be de-activating the airbag if the car had proper harnesses, seats, and a 6 point cage.
not the safest thing to have happen during an event, like you said lucky it wasn't at any high speed
** I take no responsibilty if you do this and the airbad deploys, but it worked for us**
Edit: *note, Anything to do with an airbag is usually shrouded with Yellow conduit.
When we built the blue 34 it was easy peasy. I just disconnected the battery, unplugged the driver's bag under the steering column lower shroud, removed the wheel, and then removed the entire airbag itself.
The passenger side was easy too, just dropped the glovebox out, unplugged the bag, and unbolted it. It's attached to the dash support bar, and is suprisingly heavy compared to the driver's bag :D
Edited by Marlin
In the past I definitely would deactivate my airbag. But i use a race seat and harness in my street car for track events pretty much making the airbag useless and if it did deploy would probably cause me to have a bigger accident than would have if i could see where i was going/able to hold the steering wheel.
if people are still using a street seat and inertia reel seat belt... im still kind of in two minds whats that way to go...
Interesting thread as it has been something I have thought about in the past. As mine is used on the street and stupid rules say I can't use the harness on the street then I'd have to keep it.
If this is the R33GTR I think you are talking about would it have anything to do with the previous damage caused at Morwell??
How do they deactivate airbags?
Is it done electronically or do the internals have to be removed from the steering wheel?
Basically all a CAMS scrutineer will look for is an Airbag light on the dash meaning there's a fault.
They can be either deactivated by just disconnecting them or pulling the fuse, or completely removed like my post above.
If you were to permanently disable them, I'd be inclined to remove them completely, maybe even sell them? They've gotta be worth a bob or two?
re a street car as you guys are discussing, it poses an interesting question....... I'm not sure how I'd handle it, and of course disconnecting an airbag will deem a fully registered cat un-roadworthy.
Its was ferni's car - not Scotsmans and I don't think ferni has ever had an accident that I'm aware of.
Naa no accidents.... Well not while i've had the car, and i've done plenty of DECA and Track days.... Snowy was doing nothing different to what i've done in the car. And he made a good point, imagine i was doing 200k/h into turn1 at PI and it went off, i'd be dead.
A few things.
1. Anyone got a R33 S2/S3 airbag (with or without steering wheel) they want to sell me? :D
2. Is it as simple as pulling the airbag fuse at track days to disable it? there is a fuse for it at the right drivers side knee....
3. Has anyone had this happen before? He had hit no cones or anything.... and was doing pretty much the same thing i was doing all day, sideways around cones on the skid pan.....
4. Anyone got any ideas on what i can check to see what caused it? I found some stuff on NS.com about airbag diags etc...
Reseting the airbag light ....
Just do this:
First: Open the driver's side door and get in.
Secondly: Get in and shut your door.
Next: Put your key in and turn it to the ON position(But not to start your car).
Now: Wait for your airbag light to start blinking. Then open your door and press the door ajar button seven (7) times.
Finally: Close your door and start your car up.laugh.gif
Well that's it and have fun... and if it don't work then, it must be something in the actual wires.
Airbag Diagnostics...
If the flashing still continue after you try the above sequence, your airbag has faults.
Try this:
Within 7 seconds of turning the ignition on (position II) press the drivers door switch at least 5 times this puts you into the diag mode, the airbag light should flash in a series of long and short flashes, count the short ones.
0 All OK
2 Drivers airbag module circuit fault
7 Diag sensor fault
8 Passenger airbag module fault
9 More than 2 faults present
Then ignition off wait a few seconds then back on and within 7 seconds of turning the ignition on press the drivers door switch at least 5 times this puts you into user mode.
When you go back into user mode it will cancel any errors in the diagnostic unit memory and if the system is OK and it was just a glitch the light will stay out, if there really is a problem it will start flashing again.
These is the fault codes. If it still persist, get nissan to use the consult and reset your ECU. Some of us has tried this but the flashing came back after two weeks.
I guess it could be one of many points down the signal chain that could have possibly set your airbag off. I don't know where the sensors are located in a GTR but certainly on my 33 gtst (drivers side only) the sensor has no protection from being hit by debris and i guess if the 13 year old plastic has lost some strength anything solid being flicked at it could potentially create the short required.
could also be heat somewhere that has caused the signal wires shield to melt and complete the circuit, or even just liquid to allow a short which once again could be quite possible in the position the sensor is located on my 33.
Lucky it was on a skid pan!
I would definitely remove/disable all airbags when using a racing harness....
But when using the stock seatbelts, I *PERSONALLY* would probably leave them enabled, but that's just me. IMHO the chance of them randomly going off VS. the chance of them saving significant injury during a crash makes it worthwhile keeping.
Holy crap....now I've got one more thing I need to worry about when punting my car :D
I 2nd ferni's question....does anyone know an easy way of disabling the airbags (I have a driver and passenger one) while doing motorsport ie pulling a fuse or two?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
