[group Buy] Acpt Carbon Fibre Tailshafts Any Model! $1400us
  • Replies 717
Do you know what the weight difference is between the big and little one?
Bugger it
Im in
was going to ask the same thing. for the extra 100bucks it sounds worth it.
by the way, what sort of setup will make 1000 FOOT/POUNDS of torque? let alone 1000Nm?
anyone know what sorta torque a T51R will make, seeing as thats about as big as anyones likely to run?
So we have like five? plus a possible. Any price break for five Andrew
i think i have a few more who have jus contacted me via pm, so i will message everyone when i think i have the numbers and see whos man enough :thumbsup:
but there was no chance on price break :D he said 10 or singles for the price i mentioned in the first post + delivery
OK i've just sent off another email to James, saying we're close to ready.
asked him a few more questions to clear some up in this thread.
hopefully will have some replys soon
Cheers
Andrew
is this still on?
would the advantage of the bigger one be when dumping the clutch? especially in gtr's?
i *might* be keen as i need a new tailshaft. so f**k it put me down as an almost definate.
is this still on?
yes it has me thinking that the bigger one would be better suited to brutal launches. 100bucks for extra piece of mind is worth it for me.
out of curiosity has anyone heard of anyone breaking one of these?
Not that i am aware,
search the uk forums they are widely used there more than here.
tho they are also using different brands.
i'm still waiting back on an email from James..
I knew I heard of these guys before and I went to find out where... There is a bloke from the Netherlands (whos a member on alltrac.net and ozcelica.com) who has purchased a prop from these guys and is yet to install it. It is for a 91 CS Group A Celica.
If you can get this for a 91 Celica GT4 let me know
Update: ACPT carbon fiber propshaft! B)
The original prop weighs in at 45+ lbs (20.41+ kg) according to guys on Alltrac.net, this one is 7.26 kg and 1 piece instead of 3 for the stocker. That means less rotating mass and less drivetrain losses, nice!
The carbon shaft has a fiberglass(glass fiber) coating to protect it from whatever it's exposed to underneath a car.
It has a 1,000tq rating, so should be enough for a while.
ACPT is a US company btw, which is in the carbon propshaft scene for over 30 years now. They make these shafts for everything, from 36 tonnes garbagetrucks to dragsters. They also produce the shafts for TRUST and HKS for over 10 years now, so keeping in mind I want to use as much Jap parts as possible, this propshaft is still semi JDM.
Pics:
Rear diff side:
Front:
Edited by Silly-Karr
"The 2000hp shaft is about 3
lbs heavier than the 1000 hp shaft. We will ship these individually to the
customers if you would like to do it that way or we can ship them all to one
place. Let me know what is easier for you as far as shipping goes"
that should get everyones questions answered!
ok i am going to get this underway right now,
everyone expect pm's
Also let me know which shaft you want (rating) and what car its for.
:laugh:
Edited by Angus Smart
Very close i think i have more than 10.. but a few are leaving :P
i'll obviously wait till we have 10 100% confirmations before i collect
but its still
1400us for 1000ft pounds or 1500us for 2000ft pounds
all prices in Usd, and prices include Postage!
Cheers'
Andrew
Awaiting on some messages back, if your pulling out guys let me know.
so i can quickly find some others interesed.
so far i think i have confirmations back from..
Myself
Manage13
Merli
Mr keets
Nis-26t
piggaz
7 people as i have a private buyer also.
Andrew
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
