[group Buy] Acpt Carbon Fibre Tailshafts Any Model! $1400us
  • Replies 717
Hmm... Just on 400 KW at the treads Via a 77.7 mm crank... now you got me worried!!!!!
lol, yeah, I'm unsure on the correct calculation method, anyone wish to clarify? but thinking about it basically (all my brain allows lol) is that the shaft will see more torque than the engine output.... :)
Mick
but your still only getting half the torque going through the rear wheels as up to 50% of the torque will be transferred through the front shaft on launch which would really be the only situation where you would have a chance of breaking it
Great news,
I dont have a computer monitor at home at the moment so havnt been able to keep in touch with it all.
but i get to work this morning and no emails at all. but glad its all sorted now. i still find it strange that they say he didnt have the addresses when Michael was the last to add and one of the first to receive..
Anyway Andrew(Merli) I am still waiting to hear back about yours. but i figure it is going to be yours. want to arrange a time and a place?
Cheers
Andrew
If you don't think that we'll feel any difference from the 9kg carbon shaft, then why do you want to buy a 9kg chromoly one? :)
I too am in two minds about the 2000ft/lb shaft... Reading back through the thread, we were told it would be "about 3 lbs" heavier... Even then, I should have gone with the lighter one, since I'm not making that much power... <sigh>
the reason I'll be switching because it's about the same money as replacing the centre bearing. far better to have a one peice shaft which is lighter than stock and never have to mess with the centre bearing again. and sure some small weight saving is good (even if not immediately noticed by the driver). but I don't think it 12kg-9kg would be felt. but checking other sources people say the 32 GTR shaft weighs 14kg, so 5kg saving could be a different story. :ermm:
don't get me wrong, the carbon shaft is still the awesome. and I do half wish I'd bought one! and they really were a steal at the prices you guys paid. especially for the light 1000 ones. that would have been the pick for me, cheapest and lightest. :( though Mick has good point about torque multiplication which you'd have to consider for the guys with serious power.
whilst some torque is sent to the front, on that initial moment that the clutch is dropped at potentially 8000rpm, wouldnt the main shaft take 100% of the torque for that instant, and moreso if your running on some sticky DR's? and it is only that tiny fraction of a second of high load that would do the damage id think?
Certainly for the majority the lighter shaft will reap the most benefit, but either way the bigger shaft will no doubt be a good piece of mind to the guys running or planning to run big power and launches.
Andrew, we'll setup a time & place when you've confirmed that it's my shaft...
So has anyone else, other than GTR13 with his R34 actually fitted these yet? I will not be happy if after this whole debacle, the shafts don't fit properly, and I'm going to have to f&$k around with getting a custom spacer machined up.
This 'not fitting right' deal might have something to do with not having the correct serial number, assigned to you, so untill, and if everyone can spare a minute looking up their shaft serial numbers and comparing them to the paperwork, we might never know what we have against what we should have. My setup is: R32 gtr with a 6sp Holinger and my numbers dont match. I have not attempted to install the shaft yet but would not be surprised if it wont fit.
No worries, i didnt get a chance to try to fit this weekend, i may have to wait till i can get it on a hoist as i have all under bracing that needs removing before i fit.
Well a LOT of luck for me. Looks like I came back just in time, and chased up the 'old' address.
There were 3 delivery attempts by fedex but since that address has been vacant for some time now no one was there to get it. So i call up fedex and they tell me how lucky i am, as they were going to send it back to sender TODAY. so one day more and it would of been more mess!
Finally i have the thing sitting in front of me, serial numbers on shaft and invoice matching too.
i have 0708048
ill go measure up
so ive got an 840mm carbon section and a 1120mm total, can anyone confirm the correct length for the 2000model 33 shaft?
Edited by SLY33
Well mines supposed to be for a GTR33 95model and going on SLY's measurements mine is 835mm for the carbon and 1120mm total length..
Supposed to be 2000ft/lb shaft.
At least our total lengths are the same..
It could be at my house Andrew, i only have Keith from W.a without his on the 2000hp 32gtr list.
want to arrange a time and a place to get it?
Edited by Angus Smart
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
