10pm today sitting at the lights when a black VE SS tinted windows blacker than black :P , lines up side by side with me ready to rumble revs his engine. from me no response so he revs again but a little bit higher in the rev range still no reponse from me. i can tell he wants to race me bad, trying to get me to race him. but guess what? i saw all the extra antennas on his back window. bloody cop! now that's entrapment! :(
that is just wrong!!!!! :/
has this happen to anyone else here as well?
  • Replies 70
Should have put your window down and told him SAU VIC have drag days for that kind of thing!!
I always go extra slow from the lights if someone is trying to make me drag them/similiar, so noone can get confused about whether I was racing them or not..
sad times we live in! good on ya for having the wit to realise and not give in! even if it wasnt a cop im sure u'd have puppied it off the lights and let that common whore know that racing aint for the streets. u deserve to own a 34 R if u aint draggin!
good work
what a punk.....Should have reved a bit, waited till he took off, pull over to the side then dialled 000 and reported him :(
"excuse me officer, sorry to bother you when your stuffing donuts in your mouth, but your collegue is street racing and is a major threat to public safety"
10pm today sitting at the lights when a black VE SS tinted windows blacker than black :P , lines up side by side with me ready to rumble revs his engine. from me no response so he revs again but a little bit higher in the rev range still no reponse from me. i can tell he wants to race me bad, trying to get me to race him. but guess what? i saw all the extra antennas on his back window. bloody cop! now that's entrapment! :)
that is just wrong!!!!! :)
If your car is the one in your avartar I'm amazed he didn'y pull you over for a "random" breath test anyway.
i thought unmarked police cars cant/dont have window tint? All the ones ive seen have no tint and its easy to spot the lights sitting on the parcel shelf..
Nah, they have such a dark tint you cant see through them at all. Unless you shine a torch on the window at night.
Dirty MUTHA F**king cops.
Cheapest / lowest way to entrap someone minding their own bussiness. Bastards! And I don't think I have come across any REAL Hoon who actualy revs their engine.
They usual just wait at the lights.
Cops think their being a hoon and can suck us in but when they rev the car is just making it more obvious.
Go on ya for not giving in!
I don't drag at the lights. Its just pointless and reckless.
BTW if ya did drag him, he would have shit himself, your car would absolutly destroy it.
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
