The circlip on the gearbox is back on so no more suprises. The interior is still a mess (no back seat, no headunit ect)
Did an oil change yesterday but i have not driven it much due to this damn heat wave. Ill be sorting out all the little bits when it starts to cool down.
Catch can lines need to be made, interior ect ect.
I will be out at Harry's tonight for sure at around 930ish.
Took it out for a little spin after the oil change. Im not sure if i have mentioned but im running off wastegate pressure which is 10psi. The decision to get the wastegate plumbed into the turbo housing was a great idea. Hits 10psi and stays there!
Revved it out a bit on the drive this time to about 6000rpm. Even at 10psi the thing pulls hard from 4000rpm and sound great. I estimate power to be around the 250rwkw mark.
So with E85 and 24psi tuned in two weeks who knows what it will be :laugh:
thought i saw you driving today.. now i think maybe i did. passed a white skyline on campbelltown road or something going the other way and had nice expertly installed tail lights so i thought it might be you lol
good work dave!
-and nobody knock cars that choof, mine choof's like a champ. And harden up. I havent had A/c since i bought the thing lol
good work dave!
lol That was me Jeff :D I took the long way to work.
So with E85 and 24psi tuned in two weeks who knows what it will be :thumbsup:
Nice - its still running with the GT3076R?
Im not sure if it was my imagination but after i dumped the crappy mineral oil and put in the Motul Chrono 300V, the engine felt very different.
Smoother revving,a gain in response and the turbo spooled quicker. And the way the engine pulled was like i had dropped about 50kg out of the cars weight. Noticing this especially when pulling away from lights at low engine speeds.
I guess the reduced friction in the engine is the reason for this?
Not your imagination man, definetely a difference between most oils and the 300V, its something you can actually feel. Great shit, hence why i praise it so much.
hey NYTSKY.
awsome write up, even though its not my build im quite excited for you.
i had a question about your slotted turbo.
does it really make the t51r sound? because from wat i remember the t51r isnt slotted :D
but im a major fan of the t51r but i cant justify the lag it comes with.
was hoping you had a sample sound clip or something?
how much did it end up costing you to slot the cover?
im currently running a bit larger then you (gt35r) and ive been thiking about slotting the turbo for a while now.
would you recommend it?
T51Rs definitely have anti-surge slots, they just have a little bellmouth thing over the inlet that has a gap to allow flow from the slots but covers the slots mostly from view. I can't view youtube at work though am pretty sure this clip shows what mine sounds like with the exact same turbo as NYTSKY's. Real GT3076Rs come with the slots.
Not tru, I bought a Genuine Garret GT3076R and the front cover wasn't slotted.
most of (if not all) the real 3076's come with the antisurge slots. just finished installing myne a few weeks ago, needs a tune but sounds cool
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
