you mean red top SR20, right?
Its a Red R built forged CA18, it was going to be the drag car but now is used as a daily. Its an S13 Silvia with a few GTR bits bolted on. We got pulled over in it on Saturday night when Paul was running me home but as it appears to be totally stock they left empty handed, lol.
Edited by blitzxtr
I have ordered a ASR RB30 Custom Race sump. Should take about a week to fabricate once it lands in Vic.
8.5L capacity, heavily baffled, windage doors. Boxed around the pickup. Also modified pickup.
Paul also decided to half grout fill the block, he was doing 2 other engines and had some left over lol
Looks like a new turbo setup is on the cards as this bottom end will be laughing at anything the 35R can throw at it.
NOTE: Selling a Brand New set of CP RB25 pistons. $1050+post.
16 valve :D
Must be an oldschool silvia or something.
Ah...didnt look closely enough
The new turbo wont be happening for a while. But when it does it will be a HKS T51R KAI.
Ohhh nice...what about somthing Twin Scroll though? like a 4088 or something?
Paul has a history of making at the tyres what the HKS turbo's are rated at the engine, the head needs the right little tricks though. Put the 25 head on then save some cash for the big head...or when Paul is not looking steal Twoogle's!. lol
Dave, 800whp response monster, should be fun at E.C. lol
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
