That'd be me...
Were you in the Black 33 on Corrigan Rd when I did a "smoky" U-turn???...
LOL
no sorry, i just see your car alot around springvale and even in the mornings on princess highway.
never knew u were on sau.
just look out for a gunmetal grey 32. often at the carwash at waltzing matilda :blink:
LOL
Ahh... ...That'd be where I have a bath too...
I'm there mostly on a Friday afternoon... ...I have about an hour 3/4 to kill between clients... ...If I'm feeling rich I go into the waltzy for lunch...
Spotted 2 R33's on high street at night between 12-2am white R33 and a R33 both with SAU stickers. and then followed 2 R32's at around 3am. gave you guys a hoot.
haha did u see the 2 r32's on bell street and they are both black its me and my mate with the GTR and i am in the GTS-t with veiside bodykit
Yeah it was you 2 haha i see you like almost everynight either on stud road or burwood hwy? least i think its you. pretty sure i saw you like 2-3 times tonight aswell. should lemme know when your cruising im always out :thumbsup:
White R33 turning of North Rd this morning at around 8:20. Not sure of the name of the rd but it's down near Nepean. Clogs up North Rd in peak hour.
I came flying by and caught you out of the corner of my eyes. Spotted a gap in the traffic I just had to take. lol
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
