Im surprised everyone hasnt spotted jet31 as yet, i live around the corner and it never seems to move out of that service lane.
p.s. Spotted : Mac G4 letterbox a few hundred meters back from jet31 towards
burwood hwy just before hawthorn rd. Gotta check it out.
saw myfast think it was a R33 on blackburn rd (parked) and then lil bit down the road saw jet31 (R31) parked also
Spotted a Silver with Black stripes GT-T R34 (Ferah's old car?) on Wed night - plates UQE-XXX - around 6:30pm on Josephine Avenue, Narre Warren. Followed you onto Princes Highway.
Spotted a Black GT-T R34 on Thurs night - plates WDK-XXX - around 6:30pm at the traffic lights from Tinks Road onto Princes Highway, Narre Warren.
Spotted a Blue? R32 this morning - customized plates OFF-something - around 7:00am at the corner of Princes Highway and Fitzgerald Road / Hinrichsen Drive, Hallam. Was dosing -_-"
saw a silver 33 i think s2, turning right onto springvale road from cheltenham rd today around 5.45, saw sau sticker on the window
Yeah that was me. Was getting some new $50 wiper blades from Supercheap. You would have been the low white R33 that past me heading the other way on Cheltenham road. Nice
lol yeh that was me, the front is ridiculously low (thanks to previous owner), gota save up some money to get all-round new suspension
[R34NRG] i spotted you on eastlink or other freeway i forgot tonight. i was in KAM1L the r31 u overtook n got off at stud road lol. woulda seen my car if ideicded to drive it to narre warren Krispy Kremes !! lol
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
