Spotted a gun metal EVO FQ-400!! with CE28N's (I think) & SAU stickers rolling along Alexandria Ave in Toorak yesterday. Damn that thing looked tuff as!
Thanks mate, I saw you move out to pass and didnt notice the SAU stickers until I was turning off. Nice car you have too and not sat on my tail like others do :P
Also spotted a black 33 GTST going the other way on Alexandra Parade with SAU stickers :P
i spotted mark philapoopoo's black modena on kingsway drive lalor yesterday around 11:45am
# plates :MDNA
wtf's he doing in lalor?
wtfs a modena doing in lalor?
who else has a black ferari?
Seen it in action on the tracks, that car is sex. Saff_Cossie is putting it up for sale at the moment, anyone here interested? :D
Spotted midnight purple R33 GTR along Dynon Road speeding away and overtaking everyone. :cool:
spotted a maroon R33 with no spoiler and an unpainted front end in the "good guys" carpark on princess highway in dandenong.
spotted a white R32 at dandenong plaza cinema parking.
both were bout 30 min ago.
tonight spotted RCHOO and a few others (including a very nice 34 GTR) at Le Mans in Dandenong.
mine was the black 34 GTT (stock)
Yeah i spotted the black 34
You should of come over and said hi..
We were there for a SAU -vic members Kart night..
yeah if i'd seen you guys i would have come over and said gday. you must have been on the track still when we finished.
kart night.... another reason for me to get off my arse and sign up with SAU Vic.
Edited by Norrissimo
just went noble park maccas and spotted a black R32 along side a white R33. I dunno if there from the krispy kremes meeting that went on tonight.
How was the meeting btw, i didnt get to go (school committments), where there many ppl?
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
