white gtt on the esplanade this morn.... had a lil play and a chat :wub:
then some POS stock vp conformodore had to "impress" us by doing 90 in a 60 zone darting through gaps that weren't really there :O
Well it was at 1am so i guess they had a hunch.
BTW does anyone on here know the last name or address of r31nismoid???? I need to get in contact with him; just PM me you have it.
20bux transfered via paypal or bank acc for an answer.
lol
Lol his full name is around these forums all the time. What are you planning to do with this information? Judging by your signature your having a cry over something? just get over it.
He's just a typical internet keyboard warrior; always posts some cocky, crude remark against me and when i respond he gives me a warning and/or locks my threads.
I just wanna have a man-to-man chat with him so he cant hide behind a computer screen.
True though, should just get over it.....he will always be a prick
You wouldn't happen to look like this guy, huh???...
And I think something might be wrong with the forum... ...As I've got e-mail notification turned on and one of your posts isn't showing up in the thread... ...It's so strange... ...I wonder if someone deleted it...
Back on topic... ...I think I might have spotted a Silver R35 out at the airport tonight around 9:15pm... ...wasn't too sure as I was trying to also spot my GF to pick her up...
In all seriousness though, I have all the requested information...but I want $100. Ashley's shoe size and favorite pizza topping included in the price.
Dude... ...You gave his first name away for free... ...WTF???...
Spotted a couple of skylines and other cars in the Shell petrol station carpark on the corner of warrigal and princes hwy as I was on my home from the show and shine about 4pm...
...if its anyone on here why weren't you at the SnS :)
was that sometime in the morning man? 10ish maybe?
Yeah it was about 10ish. Your 34 was nice. I was just on my way to put my new Carbon Bonnet and boot lid on. Man was that a mission. I didn't finish untill 11 that night. I love custom stuff. I swear they never fit first go. lol
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
