day: Sunday
time: 1020pm
place: Blackburn road cnr of wellington rd
driver characteristic: handsome bold young man
Was late to pick up my gf from work, so was flooring my gas on my prelude(*unfortunately, forget to refill my skyline); saw this guy next to me and was flooring hard as well but turned into monash fwy later.
spotted Johnny [GARGYA] at Epping autobarn and had a chat
Ditto, spotted nick driving a very nice white r34 gt; its nice to put a face to a nickname.
Still wondering how did you know it was me in the store lolz there were a few people in there.
also drove next to a maniac of a driver in a ferrari 360modena convertible on the way home in baby blue........tool for running the red light 2 seconds late through the busy plenty road intersection, could have killed someone.
Burn in hell you SOB!
Saw a white 34 broken down on the side on the monash near sth gippsland exit about 8pm, hope all is okay.
That was me :/ All is fine
Blown left front tyre at 100km/h, no spare wheel and no tools to get the wheel off :/ Car got towed away
Gonna look for some new tyres this weekend :(
Spotted a Green R33 GTS/maybe GTS-T at the lights on chelt rd next to keysey macas couldnt tell looked like it had a r33 GTR front bar was like Green as in Fast and furious green as in like need for speed green lol
Diver was wearing a green top to sorry mate i LOL'd hard
lol yeh brothers car while mines at centreline
lol like i said man i just picked someone and guessed, turns out my first guess was right :/
It wouldnt happen to be this one would it..?
i seen that one before also ... i nearly chucked up over my dash
its almost like a matt green :S
an R33 with some weird front. it you think it looks weird you should see a picture of it when it didnt have that front bar on :D
EEEWWWWWWWWWWWWWWWWWWW
The rego should be WTF LoL!!!!
and BA ford headlights make it even worse!!! :P
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
