'twas me, getting my wheel alignment checked as I hadn't done it in the year since I got the car complianced. What were you driving?
I was in a truck, whoever was driving your car drove it to the end of laser drv then did a u-turn, probably test driving it after the alignment!
white R33 series 2 turning right onto Waverley Rd around 13:30pm-ish. if your on here can you please for the love of god either fix them HIDs or get rid of that shit. it was so f**king bright and pointing up that it was in everyone's eyes and i could still see those f**king lights about a km down the road :)
Hey Ashneel did you see me coming home last night at about 11:30PM, just before i pulled into my court i saw your sexy tail lights. Geez R34's look good
Black 32 gtst - kitted, chromes this evening pound road...
Grey 32 GTR heading towards south gippy round about .. i was in a half rubbed down primed up 32 lol
& orange 33 gts-t with a black roof ... looked like a car from fast and furious .. turning onto greens road..
Edited by DCEIVR
white gtt with sau stickers cutting laps of oakleigh the other night.. plates WFT---
and a silver 33 in pancake parlour carpark last night who greased me off bad when i attempted to give him a reverse nod as if to say 'sup' :P
    • Hard to say, just pop the rocker covers off and have a look if you think it's cammed. You probably need to replace the valve cover gasket/half moons anyways.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
