spotted around 1.15pm today:
kryzsiu going down stud rd towards knox
and about 10 seconds later beza in his black r34 going the same direction
Haha didnt see you man, i wasnt cruising with Beza either, didnt see him lol. I was going to uni
burgundy r33 with the oldschool stickers, the ones with the two red circles, out the back of richmond station. gave you a thumbs up as i was walking. hope you put 2 and 2 together cos my car was parked a couple spots down. your car sounds sick man, like a mean ass chainsaw
haha TeamDeceptionz was that you? Nice 34 dude, sounded pretty tough too when i was getting off at toorak road... :) by the way did we have the same rims? buddy clubs?
haha yeah it was me mate. nah i have Rays; CE28's .. sorry i didnt put my window down.. i didnt realise it was a SAU member till the last minute haha.
just saw a black r33 series 2 with sau stickers leaving the side street off shrives rd near narre warren station. i think he was the one looking at a unit that was open for inspection on shrives rd think he had the bp uniform on.
just seen a white R34 GTT dropping of some on at RVO in dandy, i was squating next to my stagea weeping at the flat tyre !!!
Shouldnt you have a BIG re customs banner, especially since your car is on the front page of there website.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
