cruised into work with a silver 33 GTR Vspec today on western hwy then deer park bypass then wesgate, see him quite a fair bit when I'm running late, always gives a wave, oh and it's low as fark too. Then saw black 32 GTST on westgate bridge outbound about 9:15am. Then one more 32GTR Gunmetal with bronze rims with chick driving, you were going into Bunnings on Burwood Rd in Hawthorn, looks tuff
Silver R33 GTS-T plates "TUFR33" - Heading north bound on Dalton Rd. at 12.30am.
You got 1 tail light blown.
No need to over speed and try drag racing me, I was taking it easy and following the speed limit - What are you trying to prove??? You also mis-shifted under the bridge on take off....
All I can say is congratulations you have proved that a GTST is faster than an N/A 4 door Skyline, you have a fully sick BOV and you need help driving a manual car.
Hope you get caught the the police you fool!
Today at about 4:00 pm. going home from work ,saw a red R35 GTR (plates GTR-02),on princess Hwy. from Berwick heading Narre Warren (tryed to get closer to hear it and have a better look but couldn't because of the traffic)awesome car...btw on monday saw a purple R33 GTR in Berwick High st.Parking...
Spotted a white 33 with SAU stickers parked on Bell St Heidelberg Heights about an hour ago. Anyone from here?
taht would of been me buddy, was at the shisha cafe opposite the maccas.
also spotted a silver r33 s2 on doncaster rd yesterday dragging a audi...skyline was shootin flames o.O
Spotted a white R34 GTR on Dorset Rd Croydon heading towards Maroondah Hwy at about 7pm tonight...i think you gave the thumbs up but i only saw last minute as i was to busy looking at your car haha
was waiting to pull out of my street in the pewter R32 GTR :)
LOLLL saw/heard that i was at thomo maccas with a few mates
Saw emsta's 33 today, in a big shed in Pakenham!
so thats where it is!!!! i have been looking for it for the last couple of weeks....even called out its name....stuck up "missing" posters.......but couldnt find it :)
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
