Spotted a white R34 GTR with cf bonnet and CE28's (I think) driving beside me along Bell Street about 15 minutes ago. When the traffic banked up, I thought you'd pull up beside so I could wave at you but you stopped half a car length behind so the sun was glaring off your window and I couldn't see you haha sorry :blink:
Spotted a sweet silver 33 4dr this morning on ferntree gully road wheelers hill 9ish.
Slammed on some nice silver/chrome rims couple inches of dish. great offset/stance!!
Just wondering if anyone knows what wheels are on it??
Have seen it before around the areas before.
White r32 gtr on eastlink going inbound spotted him from the monash underpass all the way down the eastern till I lost sight of him round tram road. Had a SAU sticker on the back windscreen. Where were u going in such a hurry?
Hehe - Spotted.
You were in the grey GTR.
Sure was :cheers: I could see you coming up behind me a mile away. I was like mmm I'd recognize that shape anywhere. Nice gtr man looks tough
Sadly, probably the last time it will be spotted. Notice the hail damage all over the body? Probably a right off - will know next week. : (
Nah I wasn't close enough to see :cheers: that's no good. Hope it works out for the best
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
