Spotted a silver R34 sedan with SAU stickers on Boundary Road tonight turning onto Cheltenham Road with plates "GTTR-34" or something?
Although I was on the opposite side of the road, it sounded awesome!
saw some guy in an sau hoodie walk past my work today (tattoo shop in bacchus marsh) at about 2:30ish.
i'm guessing its the same guy who drives the sweet track looking white 31 with sau stickers which i saw parked in the main st right across from the police station...
im from the marsh btw esther... never even looked at the tatto shop and i drink at the courthouse at least once a week, lol :ermm:
Edited by thommo
Was it parked at Coles?
Or was it parked on Sir John Monash Dr?
If it's at Coles, I saw it too :ermm:
If it's at Sir John Monash Dr, then it's mine :bunny:
is yours an automatic ? with number plates that starts with UAE or something ? suppose your from United Arab Emirates yea ? think i saw yours parked in monash caulfield
it's not the same guy, that "sweet track looking white 31" is mine :bunny: ..I'm Esthers bf, was picking her up from work.
Jesse bet me to it, but yes, the 31's his. Pop into my work sometime, i'm there pretty much whenever w're open. Just let me know you're the guy from the marsh :bunny:
