Parked next to a black S1 R33 (with SAU stickers) on Southland rooftop last night.
Must've been there for a long time. I had dinner, saw a movie and when I got back to my car it was still there :/
Also... This morning around 9am I spotted a black S13 with SAU stickers turning onto Boundary Rd from Lower Dandenong Rd.
Spotted a red Supra on the Western Ring Road just before on my way home... KHOA-02 with their bonnet up... poor guy :3
Charli, i've seen you out and about about three times in the last six months!
Must live close?
My wife saw some douche bag in a silver 34 at the maccas roundabout in Taylors Lakes the other day decide to do a drift around it while it was full of traffic! kids were around as the school had let out for the day and the other cars in the roundabout all had to stop because of this tool.
Mate if you're on here I doubt you are going to own up to it but in case you are you are a spanner! oh and you can't drift too well either and that was coming from my wife!
Spotted "WANZI" out at Epping - white r34 GTT - high street (near the Cheescake Shop) - did a U-turn at one of the roud abouts.
and a black R33 GT-R pull into the Cheesecake Shop.
yep that was me, i find myself all over melbourne every weekend. in this case i overshot the first roundabout :rofl: was that u in the white 33 from the servo?
yep that was me, i find myself all over melbourne every weekend. in this case i overshot the first roundabout :( was that u in the white 33 from the servo?
Nope - I was at the cheesecake shop buying a cake for my mum's birthday :D
You wouldn't have seen my car though - I was using the the family's Daihatsu Charade.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
